Old 08-06-2009, 09:58 PM   #37
vten
no side airbags....
so is the resistor method works on the non side airbags yaris ? and how ?
thank you
Old 08-06-2009, 10:42 PM   #38
There are two different purposes to the resistors:
The 3 ohm ones are used to fool the Center Airbag Sensor Assembly into thinking that the side airbags are still present.
The 10K and 470 ohm resistors are to fool the Occupant Classification ECU into thinking that the four passenger seat Occupant Classification Sensors are present and are indicating that the seat is empty or has an adult sitting there.
This thread shows the idea behind the OCS bypass:
http://www.yarisworld.com/forums/sho...1&postcount=26
Old 08-07-2009, 11:59 AM   #39
MGargano
Drives: 2009 Yaris Hatchback
Seats are here! Let the games begin!
MGargano is offline   Reply With Quote
Old 08-07-2009, 12:42 PM   #40
1st Play - Remove the passenger seat.
Leave the Occupant classification ECU connected. Disconnect the four occupant classification sensors (on the four corners of the seat). Disconnect the side airbag (yellow connector next to the OC ECU).
When you get the seat out, take some pictures of the bottom of the seat, specifically of the sensors and how they are mounted.
Old 08-07-2009, 03:32 PM   #41
MGargano
Old 08-07-2009, 03:32 PM   #42
MGargano
Old 08-07-2009, 03:32 PM   #43
MGargano
Old 08-07-2009, 03:33 PM   #44
MGargano
Old 08-07-2009, 03:33 PM   #45
MGargano
Old 08-07-2009, 03:33 PM   #46
MGargano
This is where I'm at so far
Old 08-07-2009, 03:38 PM   #47
Very good. I would like to see behind the metal shield, if you can get that angle. I want to see how the sensors are mounted between the seat and the rail. (just brainstorming on how to keep the sensors, like the person in the other post did).
Old 08-07-2009, 03:44 PM   #48
MGargano
Looks like the metal shield is welded in place...
Old 08-07-2009, 03:52 PM   #49
MGargano
Old 08-07-2009, 03:52 PM   #50
MGargano
Old 08-07-2009, 04:10 PM   #51
MGargano
The sensors are attached to the rail with a torx screw from the outside, or so it seems
Old 08-07-2009, 04:12 PM   #52
MGargano
It looks like you'd have to physically remove the seat from the frame to get to at least one of these screws
Old 08-07-2009, 04:23 PM   #53
By meatal shield, I meant this guy (with the 060). The sensor is behind him:
Old 08-07-2009, 04:24 PM   #54
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
I can't wait to see them installed
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
