#37 |
Be Groovy!
Drives: S-Type Automatic 1.5L Join Date: Sep 2006
If weight is really a big factor and every kg counts then I think the driver has to go on a diet, and pump gas only when needed, so no full tanks and empty your bladder whenever possibe before driving :) Take it easy...
#38 |
The LittleBastard
Drives: 2007 Yaris Liftback Join Date: Sep 2006
Just ordered my ground wires off of ebay. I'll do a DIY once they arrive for those interested.
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit |
#39 |
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
thanks buddy! we'll be waiting for that...
20 years... alive and kickin'!! ![]()
#40 |
![]() ![]() Drives: '00 s2000, 2007 yaris hatch Join Date: Jul 2006
shorter gear ratio helps with acceleration too!
#41 |
The LittleBastard
^ wow forgot about gears. true that, but I think the aris already has pretty short gearing. wouldn't want to go shorter myself.
Still waiting on my wires, should come in tomorrow hopefully.
#42 |
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
#43 | |
The LittleBastard
#44 |
![]() ![]() ![]() Drives: Yaris 3dr Hatchback Join Date: Oct 2006
hey, if anyone is still reading this, i am just learning about grounding kits and all of that (of course i will make it myself when i decide to do it) but since the power steering is electric also do we need to do any special grounding for it?
#45 |
The LittleBastard
my ground wires came in yesterday. hopefully I can instal tomorrow, but if I have no time then sunday for sure.
#46 |
The LittleBastard
Here's the link to my groundwire dyi. Hope it's somewhat helpful to you guys.
http://www.yarisworld.com/forums/sho...1681#post31681
#47 |
Speed Wrenchin'
Drives: 2006 Yaris 3 door, Bayou Blue Join Date: Jan 2006
More power? Lower gear ratio. Cheapest way smaller diameter wheel/tire combo, you will feel the difference.
Quench my thirst with gasoline |
#48 | |
Good story
My Ride From Puerto Rico Yaris Sedan 07 - MODS - 20% Tints Tanabe NF2210 Suspension Two AudioPipe 12 Inches for Bass with 1000 Watts Amp BOSS 17 Inches Rims Ground Wire
#49 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
if TRD made a grounding kit....i would be able to get it free.. with the amout of ppl i know that work at the toy shop by me
"It hurts more when its wet" |
#50 |
#51 |
o dam did not look at the date on the tread.... lol sorry
#52 |
Top Five "acceleration mods" that I'm doing (with the brand I bought), all things I can bolt on myself:
1. cold air intake (AEM) 2. header (Megan Racing) 3. crank pulley (NST) 4. catback exhaust (probably custom 'cause I don't want a can, but I do like the Greddy product) 5. grounding wires (stereo store as noted) 6. lighter-than-stock wheels (SportMax for me, but whatever you like) 7. tach (knowing were redline's at IS kind of important for max acceleration) oops, that was seven. |
#53 | |
#54 | |
![]() ![]() ![]() Drives: None Join Date: Mar 2007
It's a modern car, the wires grounding it are already large enough to carry the current with minimal resistance. The reason they don't do it because there's no point. I'm sure they'd love to add 5HP to the specs sheet for basically no cost, but it doesn't work. It's the same reason they have an ECU in the car and not a 5c resistor to "Add up to 30HP". ![]() EDIT: I should mention that if you have more stuff hooked up, so you are drawing more current from the battery, then yes, you will need to run more wires through. It can also reduce static in your audio system at higher volumes. The point is, it won't "get better acceleration ?"... |
| stick vs. auto acceleration | abcando | General Yaris / Vitz Discussion | 36 | 04-08-2009 08:06 AM |
