Old 11-22-2010, 01:13 AM   #37
SiLiZiUMM
Drives: None (yet)
Ok, so with my canadian Sedan 2008 I have too the silver 08600-00997. Which, I think, do not support aux input.
Also, found the D75 aux audio connector.
Now, what are my options in order to get my aux input to work? I guess I need to change the car radio unit.
An interesting option would be to buy a used Sedan 2009 unit (satellite ready from the description):
As you see, there's already an AUX input built-in. I guess the sizes are the same, would the wiring be the same too? Aka, would it work? It would cost less than 100$CDN shipped. Good buy, or should look at something else?
Thanks
SiLiZiUMM is offline   Reply With Quote
Old 11-23-2010, 02:33 AM   #38
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
do we know who actually makes the toyota stock decks?
personally you should buy something else, get something aftermarket, the sound quality is just better.
Colin Chapman disciple
Old 05-12-2011, 08:07 PM   #39
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Thanks
Anybody know the answers to this?
I want to go this route too... I like the stock OEM look personally - so not looking to get an after-market deck.
I have an 07 Yaris HB LE. From reading above, even though my radio unit doesnt have an AUX port on front (same unit as Dave's), sounds like it DOES have the necessary aux cable/wiring behind the unit to work were I to buy the above OEM deck w/ the aux input on the face!
If I know this will work, I'm going to strart hunting around scrap yards for 08+ yarises that I could just take the oem radio unit out of.
Thanks for further feedback...
Jem
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 06-13-2011, 09:46 PM   #40
The extra connector is the aux connector, which would plug into the 4th connector on the back of an aux equipped one:
Old 06-14-2011, 09:32 PM   #41
Ahhh ok I see. So it looks like the car is wired up for AUX input but I would just need an HU that supported that 4th connection.
So is there a way to connect an AUX input to the 08600-00980 through the cd changer socket?
Thanks a million.
Correct on the first part.
Yes - There are quite a few aftermarket Toyota Aux interfaces that work through the CD changer port. Here's a $65 one for example:
http://www.amazon.com/PIE-TOY-AUX-19.../dp/B0014E9XP4
Old 08-13-2011, 07:17 PM   #42
ExocetCom
ExocetCom's Avatar
Drives: 2007 Toyota Yaris RS
Has anyone used the GTA Car Kits module? $100 seems pretty reasonable for near-full control through the stock HU, and is about half the price of the cheapest aftermarket HU with ipod/USB interface after factoring in install, wiring harness, and DIN kit.
By the looks of the GTA Car Kit video, the 08600-00999 HU, which is the one in my 07 Canadian Yaris and appears to be the same as other posters, this HU will accept the auxiliary input which is accessible as a "Disc". I'm guessing the modules that are part of the kits are used to a) allow control through the existing HU and, b) convert the output signal from the mp3 player to the correct voltage/resistance range the HU requires.
ExocetCom is offline   Reply With Quote
Old 04-17-2022, 01:33 PM   #43
IronYaris
Drives: 2008 Yaris 3dr
I have a 08 yaris hatchback, same radio as spryguy007
was anyone able to find some sort of aux/usb installation for this radio?
IronYaris is offline   Reply With Quote
Yaris review from 2006..lol rningonfumes Off-topic / Other Cars / Everything else Discussions 10 12-02-2008 03:05 AM
question bout aux port SurfBabe900 General Yaris / Vitz Discussion 1 05-28-2007 03:18 PM
