Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 08-24-2009, 08:49 AM   #37
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
Originally Posted by Lewis View Post
will do!
Just checked- no go
Lewis is offline
Old 08-24-2009, 03:23 PM   #38
mrbond
mrbond's Avatar
The combination meter gets the ABS info via the CAN bus, so unfortunately there really isn't a way to add the light to a non-ABS cluster.
lol no I meant that perhaps you could rig an external light that would do the same as the light in an abs equipped cluster. This way, finding a cluster with a tach won't be as hard.
- A Toyota Yaris
- A whut Yaris?
mrbond is offline
Old 08-24-2009, 03:41 PM   #39
Understood. My point though was that ABS is controlled by the ECM and the only indicator output is via CAN BUS message to the cluster.
CTScott is offline
Old 08-25-2009, 08:02 AM   #40
Lewis
Lewis's Avatar
The required cluster is proving virtually impossible to find for me. I'd really like to do the switch but in all honesty I wouldn't go as far as it would seem to be necessary to modify a cluster without the ABS light. There would always be the question in my mind whether the ABS is really ok. These warning lights are wonky as they are without a fool like me messing with them. Right now my 6 month old car has the tire pressure warning light lit and when I checked the actual tire pressure the tires are all ok. So it's to the dealer to get it fixed under warranty. Imagine getting your dealer to fix this problem with a modified cluster!
Lewis is offline
Instrument cluster light chriscruz2006 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-26-2014 11:29 AM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 09:53 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
