Old 09-02-2009, 12:52 AM   #1
AznGouki
Metsu
Drives: NCP91 ; E36
Sorry camelll I didn't mean to offend you man. I was just in a fritz and looking for a guide to fixing the seal on Crank. I appreciate everybody's input. Fact is I don't know what really caused the seal to break. The amount of tension that I put on the belt is no more than how much tension I have right now(dealer set it). But everything is good now and all fixed up.
AznGouki is offline   Reply With Quote
Old 09-02-2009, 04:11 PM   #2
greatnowhere
Drives: 2009 yaris 2dr hatchback
in the photos that you posted it appears that the cord from the failed belt wound around the crank behind the red pulley. if that bit of cord rotating with the crank was against the seal, i would think it would damage the seal in no time but just from looking at your pictures i would think that removing the pulley and replacing the seal would not be too hard. good luck
jim
greatnowhere is offline   Reply With Quote
Old 09-04-2009, 08:59 AM   #3
lunjiaow
lunjiaow's Avatar
Congrats on fixing it. You should have replaced the seal yourself, would have saved yourself a lot of money and time.
lunjiaow is offline   Reply With Quote
Old 08-31-2009, 10:27 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by camelll View Post
Yep the dealer is gonna laugh at you when you say you want that covered under warranty, even though the seal was probably not seated properly from the factory or was just bad and the adding the compressor pushed it over the limit. You are the only blitz owner that has had this problem as far as I know.
I do not have the lite crank pulley installed on mine, even though a lot of people praise them and say they won't hurt anything, I don't like the idea of not having a dampened pulley. Keep us posted, I am curious how much the dealer is gonna charge to fix this.
in what way is the stock pulley dampened ?
Old 08-31-2009, 10:40 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
In what way is it not dampened?
it's a solid piece of metal.
Old 08-31-2009, 10:43 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
You cut it in half and look at it, better yet if you can prove it to me that it is not dampened I will give you a brand new NST lite crank pulley!
what is it dampened with, rubber?
Old 08-31-2009, 10:45 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
Composite
lol
Old 08-31-2009, 11:12 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
If you tighten the belt tight enough to mess the seal or bearings up in the crank, you would be lucky the engine would even turn over and if it did start it would certainly shred rather quickly.
did you miss the part where the belt got shredded?
Old 08-31-2009, 11:41 AM   #9
ChinoCharles
Drives: LB
Yeah he could do that too, but I would make sure it is a trusted shop.
Well DUHHHHHH.
