Old 03-25-2010, 08:47 PM   #37
Brian
Brian's Avatar
Originally Posted by zachryboles View Post
bump for paint type
I used SEM satin black.
Old 03-26-2010, 08:54 AM   #38
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
think this would work?
http://www.krylon.com/products/fusion_for_plastic/
or maybe the rustolium brand....
zachryboles is offline   Reply With Quote
Old 03-26-2010, 09:18 PM   #39
Brian
Brian's Avatar
it will work fine. the more fade resistant the paint is, the better.
Old 11-14-2010, 09:09 PM   #40
xen555
xen555's Avatar
Drives: 3 DOORS LB
Peterpoop and Brian thanks for the DIY really help me a lot with my project!!
xen555 is offline   Reply With Quote
Old 11-15-2010, 10:23 AM   #41
PacoT
Drives: Polar White
Send a message via MSN to PacoT
before you paint the chrome reflectors, did you sand the chrome all off? or just roughly sand them??
PacoT is offline   Reply With Quote
Old 11-15-2010, 10:54 AM   #42
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Step 19:
"19.) Scuff sand all chrome parts of the headlight housing and reflector housing with 600 grit or higher sandpaper. Don't forget to pop out the amber reflector before you paint the relfector housing. You can use a flat head screwdriver. Be careful when doing so; so you don't chip the reflector."
Old 11-29-2010, 02:40 AM   #43
crolandiz
Drives: Yaris Sedan '08
Hi, how do you know wich proyector is left/right side?
Thanks.
crolandiz is offline   Reply With Quote
Old 01-14-2011, 02:14 AM   #44
crolandiz
condensation
Hi, I opened my headlights, paint and install the projectors. After 3 weeks, water or condensation appeared in the left headlight, remove the headlight for two days I let it dry and apparently went all the moisture so I went back to put silicone around.
Wash the car today morning and in evening note that the two headlights had moisture in and also the left angel eye is not starting.
What do you recommend or suggest? How can I solve this problem and prevent the more moisture?
Thank you.
Old 01-25-2011, 07:23 AM   #45
nOmi_89
Drives: 2007 Toyota Yaris
hi,
i installed my halo l.e.d projector lamp last week and the problem is when ever i connect the wires of low beam bulbs the rings are constantly switched on...whether i switch of the headlights...and when i disconnect the low beam bulbs wire it works perfectly fine on h.i.d's,l.e.d's and rings...
i can't figure it out what's wrong :( can any one help me ???
nOmi_89 is offline   Reply With Quote
Old 06-10-2011, 01:40 PM   #46
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The rings are supposed to be wired to your Park lights, so the small bulb in the headlight assembly.
Old 08-30-2011, 10:36 AM   #47
kayye
Drives: yaris yrs
sorry im new to the HID conversions...but are HID the same as halos?
and also would a H7 fit in my 09' yaris HB?
kayye is offline   Reply With Quote
DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0) CTScott DIY / Maintenance / Service 142 06-25-2024 01:47 AM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
