Old 09-30-2009, 11:15 PM   #37
LittleRed
LittleRed
Drives: 2008 Yaris Hatchback 5spd
Mods
Originally Posted by brycedudley View Post
i don't know alot about car's and will probably have to have whatever performance mod's done by a shop... but i am just wondering what i should get that is going to get me the most power/speed gain for my $$$. any suggestions?
The best thing ive ever bought for the yaris is a AFE cold air intake..it made an amazing difference in mine as well as using 91 octane gas and putting fuel system cleaners in it on a regular basis..it does give it a slight growl..but a satisfying one...you can do it yourself..its very simple..and cost about 150.00..totally worth it.... alot of bang for your buck
LittleRed is offline   Reply With Quote
Old 09-30-2009, 11:45 PM   #38
Astroman
Modded Moderator
Astroman's Avatar
Weight reduction is the cheapest. It also depends on your budget. Check out the classifieds, I purchased a used AEM intake and lowering springs, saving about $400 (the price of the springs alone if I had bought them new.) Forced induction/nitrous would be the way to go if you have the money. I went with intake, header, exhaust, pulleys and it shaved just under 2sec off my quarter mile time WITH removing the seats, spare & tools.
Old 10-14-2010, 10:29 AM   #39
magilla
Drives: yaris hatch back
how much does 07 stock hatchy weight?
magilla is offline   Reply With Quote
Old 10-14-2010, 11:26 AM   #40
hatchbackkid82
Drives: .
like 2300 lbs
Old 10-14-2010, 02:24 PM   #41
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
correct me if im wrong, but i dont think it really matters with stock 1nz engine if you put 87 or 91 octane in your tank. a stock 1nz has low compression anyways and has no real gain in power other than burns cleaner. i know as a crx owner for a decade that the stock 1.6L sohc wont produce any hp from 91 octate to 87. i personally think its more frame of mind that u put something that someone else uses thats tuned for it so u think the cars is quicker, but its really not..
i know this goes true with crx, but i could be wrong with the yaris, if im wrong i will convert to 91 octate today
Old 10-14-2010, 02:34 PM   #42
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
the NAYSAYERS will be all over this one as this has been touch upon one too many times.
DO A SEARCH on this topic and see what comes up..........
Old 10-14-2010, 02:41 PM   #43
one correction. 10.5:1 is fairly high compression, not low. I'm guessing CRX compression is even higher?
Old 10-14-2010, 07:35 PM   #44
SimTronik
Machinist
Drives: Yaris sedan 2010
Hey, was reading the thread since beginning, not sure what a underdrive pulley does. Looking for something that will lower RPM at constant speed...
SimTronik is offline   Reply With Quote
Old 10-14-2010, 08:49 PM   #45
tk-421
tk-421's Avatar
Drives: 5D-07-LB
An underdrive pulley does exactly the opposite. The engine revs are a lot more now that I have it on.
You may want to look into throttle controllers instead, since you can basically control the throttle response any way you want, and thus have better control of RPMs at constant speeds.
Old 10-14-2010, 09:46 PM   #46
SimTronik
Machinist
Thanks mister.
Old 10-15-2010, 01:57 PM   #47
jcemitte
Drives: 09 yaris sedan
This OP clearly did not read the performance primer... lol
jcemitte is offline   Reply With Quote
Old 10-15-2010, 04:26 PM   #48
mario98c
mario98c's Avatar
The best performance mod for $$$ is nitrous! /thread
Old 10-15-2010, 05:17 PM   #49
re: #44 and #45:
rpm vs speed is a function of the transmission ratio and tire diameter.
It has nothing to do with the crank pulley, or a throttle controller, or anything else.
Old 10-15-2010, 06:04 PM   #50
ilikerice
ilikerice's Avatar
crx on a stock si is 9.5:1.. i guess i was corrected that 6 octane makes a difference on a non tuned stock yaris. i assumed toyota would make a eco car to run on any gas equally. i gots lots to learn on this new found toy i gots. learning new stuff everyday.
Old 10-15-2010, 06:31 PM   #51
MadMax
MadMax's Avatar
My car seemed a lot quicker when my rear set was out...
Did you leave your rear site out? If so, is it a 60/40 split seat or the standard bench? Finally, if it is, and you would like to sell it, let me know...
Cheers! M2
Old 10-15-2010, 10:17 PM   #52
SimTronik
Machinist
re: #44 and #45:
Do you mean that with larger tire dia. i could lower my rpm at constant speed or it really has to do with the transmission too?
I reveived my fog bulbs and harnesses today btw
Old 10-16-2010, 12:26 AM   #53
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Really ???
Originally Posted by ozmdd View Post
1)Remove your spare tire and replace with fix-a-flat.
You'll DESTROY The TPMS SENSORS ad Replacement cost is not cheap !!!
bobolinko is offline   Reply With Quote
Old 10-16-2010, 10:53 AM   #54
Hard_Yaris
Drives: 07 Yaris
Please explain this. TPMS SENSORS --what they are. what they do. why they are important?
Hard_Yaris is offline   Reply With Quote
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
Just Got A yaris: Performance Mod Suggestion Marfulion Performance Modifications 23 03-09-2009 09:35 PM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
