Old 10-14-2009, 07:34 PM   #37
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Actually, Crashy is an 08 non-ABS LB.
Is it still functional, to drive a few mph at least? Sorry I haven't been reading the thread
If so, would you do the honors?
Old 10-14-2009, 07:48 PM   #38
She's fully drivable (not road legal, but still she can cruise).
She'd be a perfect test platform. And, if it doesn't work on her, I can try it on my 09 while sniffing the CAN bus to see if I can figure out a way to make it work. Thanks to my YarGauge development project I now have a fully functional homemade CAN bus sniffer.
I'll PM you my shipping address.
Old 10-14-2009, 08:07 PM   #39
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
That's the main body ECU (which handles things like door locks on a so equipped car). The ECM is the silver box under the hood against the firewall on the left side (with the two big black connectors).
Left side? I thought that the reference for the left and right sides of the car were the driver's left and right hands when seated behind the wheel. For example, on North American cars, the steering wheel is on the left side. The ECU is on the right side. Or am I wrong?
Sir A.Y. Atoyot is offline   Reply With Quote
Old 10-14-2009, 08:08 PM   #40
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Lets hope it works on Crashy.
That be really nice if you could figure out to make it work on an 07 Yaris LB if the latter doesn't work.
Actually I have a gap in my schedule to ship out tomorrow, first thing in the morning. You should get it by Monday at the latest....
Thank you Scott.
Sir A.Y. Atoyot - i think CTScott meant from the perspective of looking at your engine bay standing in front of it. It is on the right from that view..
Old 10-14-2009, 08:11 PM   #41
Correct. I was thinking of your right or left as you are standing there with the hood open.
Old 10-15-2009, 12:49 AM   #42
advocate
Drives: car
Friday Kioshi. But you don't need to buy me Lunch =)
I'll be on the 5th floor of the 7th garage parked near the stairs down. Although you'll beat me there you should park up there first.
For reference my car has 0 packages. It's completely bare bones.
Edit: Just saw you're about to ship it to CTScott. Texting you now just because we might as well try it in my car to make sure that it didn't just break or something. Might as well give it a shot before you send it off for a week or two.
Old 10-17-2009, 10:08 PM   #43
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
The cluster is in CTScott's hands now.
advocate - my moron brother mailed it earlier...
Now the fun begins....
Old 10-17-2009, 10:23 PM   #44
It arrived late this afternoon. I will give it a try in the morning.
Old 10-17-2009, 10:40 PM   #45
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
hope it was packed good enough...
Ok, cool.
Old 10-17-2009, 10:47 PM   #46
Ok, cool.
It was well packed. I hooked it up as soon as I got home tonight, but unfortunately with Crashy not having any lights, it was too dark to take it for a spin.
Old 10-18-2009, 10:48 AM   #47
I just tested it on Crashy, and the speedometer doesn't work either. She is an 08, with an automatic transmission and no ABS. The gear indicator does work, as you can see in the video below.
http://s372.photobucket.com/albums/o...r-Nospeedo.flv
So, now to figure out how to make it work.
Old 10-18-2009, 03:17 PM   #48
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
strange...maybe your assumption of it needing ABS could be true....
fingers crossed that the CAN bus can tell you how to bypass the ABS...
Old 10-19-2009, 10:51 AM   #49
My CAN bus sniffer is proving very helpful. Last night I isolated all of the CAN bus message ID's (about 24 distinct ones on Crashy, who's an 08) to specific CAN devices. This requires unplugging all of the CAN devices except the ECM, and then plugging them in one at a time and sniffing the BUS.
I then sniffed my 09 (who has ABS) and found 12 additional message IDs. I haven't isolated the 09 ones to specific devices yet, as the devices are no where near as accessible as they are on Crashy. One of the new ones that I found on the 09 corresponds with one that someone doing CAN development on the Prius figured out to be the broadcast message of the vehicle speed.
So, hopefully tonight I'll have time to run my 09 on stands while sniffing the "speed" message to see if it does correspond.
Old 10-19-2009, 12:13 PM   #50
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
If the 09 corresponds to the Prius broadcast message of the vehicle speed, what would that mean?
Isn't the speed some how related to the mpg meter on the Prius. I know on the older models depending on what speed you were cruising at, it corresponded to the mpg you would be getting....
Old 10-19-2009, 12:35 PM   #51
The ECM gets the speed info and then broadcasts it over the CAN for whomever needs it (power steering ECU, etc.). The only significance to the Prius is that someone figured out that particular message. Other than the standard OBD protocol over CAN, there is little to no information out there, so it typically takes lot of work to figure out what data the messages contain.
Old 10-19-2009, 12:48 PM   #52
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Oh, i see, that would make it easy then. Hope it matches up to the Prius's code, seeing that they both use the 1.5 liter engine...
This cluster just went from being interesting to complicated in my head now...lol
Old 10-19-2009, 02:05 PM   #53
It is looking like the two possible solutions for it may be:
1. Install an ABS equipped ECM (but then the question is if you have an ABS ECM without actually having ABS will there be any issues).
2. Build a device that simulates the broadcasting of the speed data. This one sounds crazy, but is actually not that bad. With my YarGauge development work, I have a reference design that I can use. I can already read the speed from the ECM, so I just need to repackage that data into the correct message for the cluster.
Provided that I can figure out the CAN messaging for speed (or that the Prius message ID is the same and therefore I already have), then this is actually fairly simple. And, the hardware that I am using is not too expensive, so I should be able to provide a packaged solution for about $30.
Old 10-19-2009, 03:23 PM   #54
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
sounds like a lot of work
looks like it would of been better just to get the USDM cluter, its a bit more but at least everything will read out in MPH rather then KM.
I would buy a car with a swapped cluster that was in KM
http://www.4055design.com
My JDM Yaris..(Vitz Rs Wannabe) ^^ davinelika Photo-Video-Media Gallery 20 10-05-2010 08:08 AM
OZ CLUSTER Lewis DIY / Maintenance / Service 226 11-15-2009 08:19 AM
FS: Gauge Cluster from '09 LB- $150 MGargano Items for Sale by private party 14 10-05-2009 12:59 PM
A German Yaris/Vitz/Echo ;) we-to-11 Photo-Video-Media Gallery 5 06-27-2007 08:26 PM
JDM Vitz Parts!! MC-BPT Sponsors Classifieds Area 20 06-20-2007 02:44 PM
