Old 12-01-2009, 11:50 PM   #37
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
I had to fight really hard (for my road types, terrain, etc.) to get my MPG up past 40.
Mid to upper 30's is what I usually get, and seems to be about the norm with prudent driving. You're not doing anything wrong. If you did 55 on those roads, you would easily bump up past 40, but that's probably not safe, eh?
Old 12-02-2009, 12:00 AM   #38
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Yep, your fuel consumption goes up pretty fast as your speed does.
Old 12-03-2009, 09:29 PM   #39
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by Sandwash View Post
What am I doing wrong in consistently getting 36 mpg? Maybe regularly traveling at 75 mph per speed limit as generally indicated on primary so. Az roadways?
Congrats for all getting beyond expected mpg for yaris, of course. For comparison purposes it would be useful to include guesstimate of av. speed thru time, in addition to mpg.
--thanks.
Things to try: check your tire pressure, low pressure kills mpg; pretend there is a hand grenade beneath your gas pedal, the slower you accelerate the less gas you burn accelerating; DFCO is your friend, take your foot off the gas as much as possible and just coast in gear; try using the ac as little as possible, as it sucks up gas too; slower is always better, just because the limit is 75 doesn't mean you should do it, it is a limit, not a speed suggestion.
Colin Chapman disciple
Old 12-05-2009, 06:20 PM   #40
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Now that my car HB Yaris has gotten broken in(22000miles)with stock intake,exhaust and tires and wheels on it I am gettign constant readings of 40-42mpg.
In the spring when the intake,exhaust,and 17s go back on I am hoping it stays in the 35mpg range,last year it was in the 32mpg range with them on,and although still decent I enjoy my 40+mpg right now.
Old 12-06-2009, 12:35 PM   #41
why?
why?'s Avatar
Drives: Yaris LB
are your stocks the 14's or 15's? 17's kill mpg like you wouldn't believe.
Old 12-09-2009, 07:56 PM   #42
docB
Drives: '09 Yaris Sedan
Does anyone shut the engine off at longer stops? I shut down if the lights have just turned red. I never hold up traffic for the sake of a drop of gas. Safety first. If you aren't moving and the crank is turning...zero miles per gallon.
I never hold up traffic driving 5 under either. I always try to at least maintain the posted speed limit on highways, too. This Yaris has also broken at least one major speed limit sign...
doc
docB is offline   Reply With Quote
Old 12-09-2009, 11:34 PM   #43
Yaris Hilton
Smile
I don't shut it off at traffic lights, but do in drive-through lines.
Old 03-08-2010, 09:49 AM   #44
127.0.0.1
7000 miles on the yaris now
on a 135 mile route, that I maxed 38.9 mpg at [600 miles on the yaris....]
in 'as close to identical conditions' (temp, winds, speed)... when I did it last night I got 41.1 mpg
tailwinds no, traffic same, car is 60 lbs heavier....
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Why is my new 09 Yaris MPG is so low soup1207 Fuel Economy Forum 34 06-12-2009 04:45 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 05:23 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
Toyota Yaris achieves over 84 mpg in MPG Marathon tk-421 Off-topic / Other Cars / Everything else Discussions 5 11-17-2008 08:41 PM
