Old 01-08-2010, 07:04 AM   #37
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Originally Posted by devinlamothe View Post
At least you don't have 15% everywhere ... it really eats your mileage.
Do you have E15 in Canada?
Old 01-08-2010, 07:45 AM   #38
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Yes, at most of the stations where I live it's all E15. There are some with just E10 but not many.
devinlamothe is offline   Reply With Quote
Old 01-10-2010, 06:49 AM   #39
captainm27
Drives: 2008 Sedan A/T Silver
Why do I get terrible gas mileage in the winter?
I know every car suffers MPG drops in the winter. But why is that? Is it because of the winter blend type of fuel being used? Or does an engine use more gas to stay warmer during the coler months? I drive my Yaris the same gentle way I do in the winter as I do during the warm spring days (with the exception of snow storms, etc.) I never see my RPM's going so much higher to suggest using more fuel. Does the engine use more fuel, even though it is keeping the RPM's at the same levels? Or is RPM just not a good indicator of how much gas is being used?
captainm27 is offline   Reply With Quote
Old 01-10-2010, 06:55 AM   #40
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Winter blend fuel, you use the heater (electric more), and in my case I have 4 snows mounted........ not too mention there is more resistance on the roads with slush and snow...... longer warm-ups.....
I usually average 36-38 in the winter and during real bad weather as low as 32
Old 01-10-2010, 07:00 AM   #41
captainm27
I can see the winter blend fuel, that's what I think is affecting the most. I didn't know the heater requires that much more energy. During the spring and summer, I have my fans / AC blowing all the time. I usually don't warm up the car. Just turn on, shift to drive, and go. I can understand the slush and snow, but for the most part, here in NJ, when it snows, by the next day most roads are cleared. Hmm......
Old 01-10-2010, 07:09 AM   #42
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Well, my "cool" light takes longer to turn off in the winter so the engine is not up to temperature as fast. The tires do not expand and heat up in the winter either.
Old 01-10-2010, 11:23 AM   #43
b_hickman11
Drives: 08 Sedan
Your engine likes warm and hot air to be brought into it from the intake. The hotter it is outside, the better mpg's you will get. I recorded my best mpg on a day it was 105+ degrees outside.
Old 01-10-2010, 11:38 AM   #44
Hershey
winter is good for nothing .
Old 01-30-2010, 12:11 PM   #45
Hard_Yaris
Drives: 07 Yaris
Here in Edmonton We get good week long cold snaps of -20C.
I never let my car Idle long, and have never had to plug it in even at -35C... It started with a few more turnovers.
My question would be: Would it help with millage to have a warmer engine bay with temperatures of -20 and lower?
I find my water Temp to be around 85C when its that cold.
Hard_Yaris is offline   Reply With Quote
Old 01-30-2010, 01:24 PM   #46
MadMax
MadMax's Avatar
Maybe that explains the good mileage I got this past summer, when we had all those 100+ degree days...
I can't wait for those days to return!
Old 01-30-2010, 06:06 PM   #47
Hard_Yaris
Drives: 07 Yaris
So in this case Hot Air is Good!
Old 01-30-2010, 06:34 PM   #48
BailOut
Steals terrorist's lunch
BailOut's Avatar
Precisely. This is why many of us hypermilers block our grilles in the cold months, and why some also set up DIY warm air intakes.
- Brian
Share the Road
Old 02-26-2010, 03:39 PM   #49
SQUARE HEAD
Drives: 2008 yaris sedan
MPG
Originally Posted by schleppy View Post
My MPG almost always drops in winter. So far I'm seeing 2mpg less than summer.
MY LITTLE MULE USED TO GET AT LEAST 40MPG BUT SINCE THE COLD WEATHER MY MPG IS NOW DOWN TO 34--35MPG...SAME DRIVING HABITS ANY SUGGESTIONS??
SQUARE HEAD is offline   Reply With Quote
Old 02-26-2010, 04:23 PM   #50
127.0.0.1
wait for summer
or throw a blankie in front of the radiator
Old 03-17-2010, 06:22 PM   #51
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
When does the Northeast switch over to summer gas?
Twistoffate0817 is offline   Reply With Quote
Old 03-17-2010, 10:50 PM   #52
Hershey
usually in APRIL . Flowers bloom as do gas prices .
Old 03-18-2010, 07:12 PM   #53
docB
Drives: '09 Yaris Sedan
HA Ha ha
We don't have summer and winter blends any more. All the gas is cut with ethanol all year round. The alcohol just cuts your milage and raises the oil company profits. The environmental benefit just doesn't make this a good proposition. Flex fuel vehicles are as big a joke as HEVs.
doc
docB is offline   Reply With Quote
Old 03-18-2010, 07:15 PM   #54
docB
Everything needs to warm up. Oil, grease, water, and the passengers. All that heat plus wipers and defrosters use up extra fuel. The DEF mode for the HVAC runs the air conditioner, too. The snow on the road offers a tremendeous drag that needs to be overcome.
doc
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Do you get about 4 MPG less during winter ? paraganek Fuel Economy Forum 24 05-18-2009 09:52 AM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
