Old 11-15-2006, 01:25 PM   #1
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
He clearly stated that he was doing it for looks. To which you reply with a question about why he want's to increase the rear track....wait a minute...you asked him why he wants to increase his rear track greater than the rear. What are you asking?
at any rate, he's doing it for looks. If he wants to run a 10" wheel with 0 offset, so be it. He's doing it for looks.
Not everybody wants to be a Johnny-go-go-speedracer.
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline   Reply With Quote
Old 11-15-2006, 01:48 PM   #2
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
you sound hostile.
it was a simple question, who cares if it is just for looks, you still want it to drive straight, and i'm pretty sure he'll go full throttle from time to time, and take a couple corners above the posted reccomeneded speed.
and yes it was a typo on my part, I was asking why he was increase the rear track greater than he was increasing the front. I'll edit the original post, so not to confuse anyone further.
Russelt3hPirate is offline   Reply With Quote
Old 11-15-2006, 01:56 PM   #3
the_saint
50% borikén
the_saint's Avatar
Nope, no hostility.
I guess my point out of the whole deal is that it sounds like it's purely asthetical and he probably is not concerened with performance.
'06+ Toyota bB
Old 11-15-2006, 02:17 PM   #4
Russelt3hPirate
l33t3st Asshole
Nope, no hostility.
even aesthetically pleasing mods shouldn't have adverse effects. at least IMHO.
Old 11-15-2006, 03:46 PM   #5
kngrsll
Apexing Egg!!
kngrsll's Avatar
i agree with that. anyone see the sport compact car article with the two 350Z's on the cover? one was done by a guy with track events in mind and the other was a w00t street racer guy and had all the name brand bling on his. well the thought out sorted track car just destroyed the other.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 11-16-2006, 08:20 AM   #6
03Z33
03Z33's Avatar
Drives: TCR10
I never read the article, but I was at the track that day and those cars where both crap! I know the owner of the "FI" car which also happened to have crap aligment, 400 lbs. of stero stuff, and crap tires IIRC. Those guys are the most useless magazine writers, and I can only imagine how crappy that article reads. We where at Horse Thief that day (right above the streets course) and we had 4 Z's at the event (including mine). My Z is mostly my track toy at this point, I rarely drive it on the street, but I still like to run stylish wheels, which includes running wheels with negative offset, huge lips and stretched tires. I haven't found any downsides to running these on the car so far, I'm sure the wheel bearings may wear early, but I change those once a year anyway as preventative maintenance. I actually really like the feel of the wider track, it gives the car a lot more stability.
Regarding your autocross setup, I wouldn't recommend the 15x7 +22's they'll stick out too far and you won't be able to run a decent sized tire. You want to try and stay in the +30 or higher offset range if you plan to run a 205 or wider tire without major rubbing. My track wheels right now are 15x7 +35 and they fit nice and flush with 195/55/15 Bridgestone RE55S (r-compounds) this tire is know to run wide, and I also increased my front camber to max (-2 deg) by purchasing the thinnest camber bolts from Toyota (12.4mm vs. 15mm stock) for both mounting holes, and set the strut to max neg. camber on both sides. Toe is set at 0.
I have more than 5 sets of wheels for the Yaris already, I like trying out different setups, and the style wheels are just that, for style. The look I'm after is a deep dish, and to achieve that it's necessary to go with a lower offset. I didn't want to compromise the front too much, so I stayed with a somewhat conservative offset and ~3" lip. On the rear I'll have almost 4" lip and peformance shouldn't be adversely affected noticably, but I'll make sure to give my honest oppinion if I find out otherwise.
03Z33 is offline   Reply With Quote
Old 11-16-2006, 08:54 AM   #7
kngrsll
Apexing Egg!!
kngrsll's Avatar
i think im going to get a set of 16x7's and run a 205/50/16 azenis on it. ill pick up a set of 15's with R compounds for track when i start going. at least there are alot of choices when it comes to that size tire.
Old 11-17-2006, 03:07 PM   #8
Russelt3hPirate
l33t3st Asshole
the only reason i have no issue trying the +22mm's is they will be free to use/borrow for a test run.
last thing i would do is buy wheels w/o testing something as a gauge.
Old 11-27-2006, 02:20 PM   #9
Russelt3hPirate
l33t3st Asshole
well, drove home the new yaris yesterday.
tests fits should start soon, prepping shortly there after.
anyone know of seatbrackets for the yaris/vitz?
Old 11-27-2006, 04:57 PM   #10
the_saint
50% borikén
the_saint's Avatar
TRD bracketsDon't know where to get them, but at least it gives a part#
'06+ Toyota bB
Old 11-27-2006, 05:48 PM   #11
Russelt3hPirate
l33t3st Asshole
I'll have no issue sourcing JDM Toyota parts, thank you for the part #!!
now just to find out if recaros will bolt to them :)
Old 11-27-2006, 07:43 PM   #12
platypus
Drives: Yaris Sedan
keep us posted. better/stickier tires and better seating are the two mods high on my list.
platypus is offline   Reply With Quote
Old 11-27-2006, 07:52 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
not to ruin everyones fun, but why is everyone runny such skinny tires? 185, 195, 205? I went up to a 225-50-15 with no problems 15x7 +38 wheel, this thing corners like a go-kart
Old 11-28-2006, 02:10 AM   #14
03Z33
03Z33's Avatar
Drives: TCR10
Bride also have a part number for the NCP91 Vitz/Yaris, sorry I don't have it available but you can order it from most Japan dealers or Tees USA the Bride importer can bring it in for you. Most of the Bride brackets will fit Recaro buckets also.
The JDM TRD brackets for the JDM TRD-Recaros will probably only fit the narrowest of bucket seats. The link above is only for a bottom mount which only works with the reclineable TRD sport seat.
Here's a link to the TRD buckets:
http://trdparts.jp/parts_trd-recaro.html
VERY PIMP!!! to bad my fat ass will never fit them :(
Old 11-28-2006, 06:32 PM   #15
platypus
Drives: Yaris Sedan
you put 225's on a 7" rim? Do you run low pressures to get the tread to lie flat on the track? It seems to me (being the veteran bench racer that I am) that a 225 is a bit wide to put on a 7" rim unless you're going for a bit of roundness in the tread (which can help with a more progressive breakaway).
Old 11-28-2006, 03:41 AM   #16
spkrman
Drives: 1
yep, I have yet to find a racing seat i'm 100% comfy in.
Old 11-28-2006, 06:00 PM   #17
platypus
Drives: Yaris Sedan
as a total lardass, I can wholly recommend the Sparco Evo3 (which you can get from Subesports). Now what brackets would make it work in a yaris...
Old 11-28-2006, 06:11 PM   #18
Russelt3hPirate
l33t3st Asshole
since the sparco evo3 is a sidemount you'd just need a base and then a set of side mounts that work.
I'll be looking into the bride stuff too.
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
