Old 04-15-2010, 12:10 PM   #1
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Plus, tank topping provides a variable amount of gas above the full point on the gauge.
About 1.2 gallons. Takes the tank range from about 450 miles to 500+ miles. But, traditionally speaking, nobody cares about the accuracy of the gas gauge above 'F'. Interest *begins* at 'F' and steadily increases as the needle approaches and descends past 'E'.
-Steve
sbergman27 is offline   Reply With Quote
Old 04-15-2010, 12:39 PM   #2
Hershey
don't top off our cars anymore . Thanks to damage it can cause to the evaporator system . Here's a reason not to , www.mpt.org/motorweek/goss/2930.shtml .
Old 04-15-2010, 12:47 PM   #3
sbergman27
sbergman27's Avatar
But the charcoal canister is safe under the hood of my 1988 Sprint. There is no reason that a charcoal cannister should be vulnerable to topping the tank off... other than bad design. Why can't the canister be mounted above the top of the tank so that liquid overflow is not a problem? Why does the Yaris have such crappy, fragile, and poorly positioned fuel system components? Or is this, perhaps, just hearsay, too?
-Steve
Old 04-15-2010, 03:14 PM   #4
127.0.0.1
-Steve
it is hearsay. most vehicles have the same issue. fuel system components are
tightly designed and WELL THOUGHT OUT by very smart engineers so it
won't catch fire in an accident, yet still do it's job.
half the comments on this forum assume no thought went into each and every piece of the car, but the fact is: millions were spent on very careful analysis of everything, bumper-to-bumper. you want it different ? buy a different car, case closed.
Old 04-15-2010, 07:39 PM   #5
sbergman27
sbergman27's Avatar
Originally Posted by 127.0.0.1 View Post
...but the fact is: millions were spent on very careful analysis of everything, bumper-to-bumper...
Even more importantly, we build upon previous experience. We've been building cars since the late 19th century. To be sure, requirements change. But the EVAP system was introduced on GM cars, which are what I happen to be most familiar with in that period, in about 1971. The industry has had 40 years of watching their own and others' designs to get the basics of that system right. There is no legitimate reason for current EVAP systems to be so vulnerable as some claim.
-Steve
Old 04-15-2010, 11:58 PM   #6
BailOut
Steals terrorist's lunch
BailOut's Avatar
The problem is that even if you don't damage the EVAP system by overfilling you're causing huge amounts of raw emissions to come blasting back out of the filler neck and right into your local atmosphere. These fumes are carcinogenic (cancer causing) to humans and toxic to most plant life, so one should not cause nor experience unnecessary exposure.
The auto-stop feature on fuel pumps is in place for a reason.
- Brian
Share the Road
Old 04-16-2010, 01:02 AM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I would guess that it would be between 3 to 4 gallons.
Old 04-16-2010, 02:05 PM   #8
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
@sbergman27 - fuel pump
Actually your pump will not `blow up' as soon as you run it dry. However, it is then sitting in an empty tank with a little air, plenty of residual fuel fumes, and that is certainly somewhere that you don't want a spark to occur from the motor brushes or to have lots of excess heat.
Many modern pumps pull the fuel right through the pump motor and everything whereby the liquid fuel is helping to lubricate the pump and keep it operating cooler.
A 50's or 60's pump may have had slightly less wear or damage from running dry, but it would never have continued to be efficient at the 400K miles and beyond that the current pumps are doing.
The newer pumps are also 1/3 to 1/4 the size and weight of those old style pumps, which certainly helps in the Yaris.
By the way, I was making drafting changes to designs of GM fuel pumps of this type back in the late 80's, in my first engineering job. (while still in school) You can bet every component in a modern fuel system has been reviewed and improved dozens of times.
The modern pump is in fact designed so it can safely run dry...on occasion. But you shouldn't do it every fill up. The current design was optimized to extend the life of fuel system well beyond the vehicle life and to minimize weight.
I think there is a lot of really good design work evident in my Yaris for the money that I spent on it.
SpaceShot is offline   Reply With Quote
gas gauge cali yaris Performance Modifications 19 01-16-2009 08:41 PM
gas gauge issue Bretsuaz General Yaris / Vitz Discussion 2 06-14-2007 11:00 PM
gas gauge and wiper jet spray Adriaan DIY / Maintenance / Service 4 06-03-2007 02:13 AM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
