Old 07-19-2010, 01:40 AM   #37
fett22
Drives: 2004 yaris t-sport turbo
after adding exhaust taking out the cat, i went to dyna, and my car has 122hp at wheels,132 torque, still need to add a new clucth , kn filter.
From trd specs mi car should have 125.26 hp at wheels, so 122 its not bad at all.
Will post dyna sheet soon.
I am running an autometer boost gauge,and oil pressure, still need to change my Bov, still loosing some air.
i will get and Super AFC 2 pretty soon and a manual boost control ,also planning to add AEM water meth kit.
To push everything up to 160 hp.
fett22 is offline   Reply With Quote
Old 07-19-2010, 09:59 AM   #38
TTS
Drives: yaris T sport turbo
Hi everyone, Fett22 is a friend of mine.. I have a Yaris T sport TRD turbo. Running AEM water/meth inyection, boosting 8-9psi, K Y N filter, lightweight NST pulley, ACT stage 1 (street) clutch, 2 1/4 exhaust, no cat.
Last time I went to the dyno my car put 165lbs torque and 162whp..
What I need right now is a TRD Helical LSD... I someone has it.. I really need it..
TTS is offline   Reply With Quote
Old 07-19-2010, 11:24 PM   #39
fett22
yeah this yaris moves so fast, hopefully mine will do the same in a while.
Old 07-20-2010, 02:12 AM   #40
I like the Kaaz LSD, it's a better feel.
can you post a dyno chart?
Old 08-05-2010, 09:58 AM   #41
Did you ever check to see what you CEL codes were?
Old 08-07-2010, 11:48 PM   #42
sleey0
Drives: 2008 Yaris LB
You, my friend, have brass balls doing this install to such a new vehicle.
Incredible and awesome, though!
sleey0 is offline   Reply With Quote
Old 08-15-2010, 06:37 AM   #43
Zamal7591
Drives: TRD turbo vitz
I need the ECU diagram for the 1 NZFET please!! I have a VDP , and i need to connect a wire to the ECU!!!
Zamal7591 is offline   Reply With Quote
trd turbo plan
Trd sport M badge (carbon RARE), td05 Mitubishi turbo flatline16 Items for Sale by private party 14 09-28-2010 07:20 PM
TRD Turbo Vitz 田中秀樹 Forced Induction Forum 26 09-26-2007 03:07 PM
Yaris Sport Turbo BY TRD Fer.pa Central and South America 18 07-31-2007 12:05 AM
TRD Turbo ECHo Hatch - Yaris TS CASTREX General Yaris / Vitz Discussion 12 04-03-2007 11:04 AM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 04:51 PM
