Old 12-22-2012, 11:25 AM   #37
HighMilesForLife
Drives: 2008 Black Yaris sedan
Correct, I popped the 120A fusible link for the alternator. before I figured out how to get the plastic cover off, I went to the Yota dealer with a different car and spent 30 mins not being able to find the correct part # to order, and no one knew what I was reffering to even with a pic. Not sure how theyd never seen this happen before. So, I bent the link back together with a screwdriver, its pretty strong metal so everything works in the car now. Those fusible links do not look removable to me....
So my questions are now, does anyone have the exact part # for the 120A fusible link on a 2008 Yaris? And also.. how the hell does that thing come out? It looks more sensible to just solder it and leave it alone, and making sure the battery is all unhooked before I start working on things in there. Is soldering a bad idea? It's already touching, so a proper solder job should not allow for over-amperage. Thanks again guys.
HighMilesForLife is offline   Reply With Quote
Old 12-22-2012, 05:49 PM   #38
They are not replaceable individually. You have to remove that section of the positive battery terminal to replace it.
The part is called the "block assembly, fusible link" and the part number is: 82620-52050
It is about $12.
Old 12-23-2012, 01:52 PM   #39
HighMilesForLife
Okay, if the parts department in Albany does not figure that out at least I will have exact information to give them now. 12 bucks for that whole piece is decent. Thanks!!
Old 05-11-2013, 02:18 PM   #40
If you look up into the wire entry end of the black connector, does it look good there? Also, how about up into where the black connector plugs into?
Another thing to check is on the face of the under dash fuse panel there is a very large black wire that plugs into a large one pin connector on the fuse panel. Check him and also take a voltage measurement on him.
Old 04-19-2016, 11:44 PM   #41
bruceisthecat
Drives: 2007 Toyota Yaris
YESSSS
Originally Posted by brg88tx View Post
lemme guess, your electrical problems started right after you replaced your failed water pump....riiiiight.
I just did that and now is happening to me, can't you help?
bruceisthecat is offline   Reply With Quote
Old 05-25-2020, 06:31 PM   #42
rmshort
Drives: 2007 Toyota Yaris 3dr
I've been having major issues with my Yaris over the past few days, tried everything I could think of to get her back to a state of reliability. It started the other day when she stalled on me, so I replaced the battery, and then she continued to stall shortly after starting up again and again. The next day she started right up with a bit of starter fluid(through the MAF sensor port, MAF plugged in, resting in the crevice between the battery and airbox), which lead me to believe it was fuel related. Checked fuel pressure, and it was on par. Then when I hooked the fuel line back up, she started and ran again. I tried to get in and take her for a ride, only to find I could barely turn the wheel in P, and even more difficulty in D. Today I woke up and decided to go get new battery terminals. Hooked them up to the new battery and jump-started, after that no problems. It's been a very confusing few days, I can only hope she's done being difficult for a while.
rmshort is offline   Reply With Quote
Old 04-17-2021, 04:54 AM   #43
Oilhoots
Im having similar issues with my car as well but from all CCT has been saying I'm guessing it's some kind of power issue some where along the wire or connections so a full inspection of it should lead me to the problem
Oilhoots is offline   Reply With Quote
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
solar trickle charger and alternator wingdood Fuel Economy Forum 33 10-12-2009 04:02 PM
