Old 09-25-2006, 02:48 PM   #37
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
I wish I had the cojones to cut a hole on my roof
YamilR is offline   Reply With Quote
Old 09-25-2006, 03:06 PM   #38
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Originally Posted by corey415
Did you do the install yourself "Violin"?
Looks great btw!
Sure did. Nothing like cutting a hole in a new car.
Thanks for the compliment.
Old 09-25-2006, 03:09 PM   #39
Violin
Violin's Avatar
BTW - If anyone is thinking about doing this themselves - rent/ borrow/ buy/ steal electric metal shears. You'll make a mess with a jigsaw.
Old 09-25-2006, 03:27 PM   #40
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I'm gonna see what an install shop wants me to pay to have one installed before i attemp this one... as its kind a perm. mod (unless your a good body wrk'r).
hows the seal work? its it a combinations of a rubber "strip" and caulk..
will work for parts
Old 09-25-2006, 03:44 PM   #41
Violin
Violin's Avatar
This was my third time. The first two were just pop-ups.
You may have heard the expression in carpentry: "measure twice, cut once".
Here it's "measure 57 times, cut once".
The instructions with mine showed a strip of butyl rubber tape to seal between the frame and the roof. It didn't come in the package so I called the manufacturer. They said they stopped using that and recommended I use that black silicone made by Permatex - it's a non-corrosive silicone for use on metal.
Old 09-26-2006, 11:22 AM   #42
vodkalush
I drive a yarrrris
vodkalush's Avatar
ummm....
well I think thats somthing I might takel next spring/summer as its getting close to winter time.
btw great job. post updated pics when you re-tirm the intertior edging.
will work for parts
Old 09-26-2006, 03:24 PM   #43
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
looks great violin! i would love one of those.
is there any structural stuff that was in the way, or just straight sheet metal?
stuffy is offline   Reply With Quote
Old 09-26-2006, 08:01 PM   #44
Violin
Violin's Avatar
Not structural - there is an anti-flutter bow that the interior dome light is attached to. I had to remove that and relocate the light. Three bolts at either end, bend it down, cut it and pull forward to pop the little spot weld at each end.
Relocating the light was tricky.
Old 09-27-2006, 09:06 AM   #45
oscarying
Drives: SLOOWZ
where can i do it in sydney :(
it looks HOT!!
oscarying is offline   Reply With Quote
Old 10-16-2006, 07:47 PM   #46
imknotright
Drives: 07 Yaris sdn
What exactly is an "anti-flutter bow" & what was so tricky about the dome light relocation? I have done a few pop ups in older cars with not much to lose if i messed up. Just want to have my facts straight before I cut away.
imknotright is offline   Reply With Quote
Old 10-16-2006, 10:14 PM   #47
Violin
Violin's Avatar
The anti-flutter bow is a piece of metal that runs across the roof to keep the sheet metal from flapping at highway speeds. The side rails provide the structure so it can be removed as the sunroof frame is stiffer than the sheet metal it replaces.
If you look at the light in the hatchback, you'll see that it sits in a recessed cup molded into the headliner. Placing it flat on the ceiling doesn't work. If I could have found a decent looking surface mount dome light with a door/off/on switch I would have replaced it.
To mount it, I glued two pieces of foam to a thin piece of wood to make a support with a recessed area in the center for the light to sit in and put that up behind the headliner. I used the light lens as a template and cut a hole in the headliner exactly that size where I wanted the light. I cut off all the protrusions on the back of the light and put two screws through it (with the lens removed) into the wood blocking above. I practiced with the piece of headliner I removed from the sunroof hole. You may come up with a different way to mount it.
If you’ve done a pop-up, this is not much more complicated. Running power wires is an added step, but the end result is so much nicer.
Old 10-17-2006, 11:53 PM   #48
RSboyz
RSboyz's Avatar
Drives: 2007 Yaris RS
violin your installation on the sunroof looks FLAWLESS! how much did you spend on the sunroof itself? and was it a big hassel to get it install? even tho i could already imagine it would be. i want a sunroof on my yaris but the shop is asking for 1600 for it >.< so im jsut thinking if its something thats NOT TOO DIFFICULT then i might go ahead and do it
RSboyz is offline   Reply With Quote
Old 10-18-2006, 07:10 AM   #49
Violin
Violin's Avatar
The cost of the sunroof was $350 shipped. I spent maybe another $20 on sealant & parts. It took me about 6 hours - much of that was spent on moving the dome light.
Old 10-18-2006, 04:54 PM   #50
RSboyz
RSboyz's Avatar
what you guy think if i order the sunroof and then bring it to the shop to install it? bcuz i dont trust myself cutting a whle on my car
Old 10-18-2006, 06:11 PM   #51
Violin
Violin's Avatar
Probably best to let your installer get the sunroof. They get a better price than you ever could.
Old 10-18-2006, 11:16 PM   #52
RSboyz
RSboyz's Avatar
but the shop i have is asking me for 1600 CAD plus roof and labor after tax. the guy told me is gonna be a 16 or 18 by 32 and he said one touch open and close, tilt and other features but i jsut want a sunroof that can slide open
Old 10-19-2006, 07:25 AM   #53
Violin
Violin's Avatar
That's for a moonroof. A spoiler sunroof should be cheaper than that. There is a lot of labor involved and liability for fit, leaks, etc. so they charge you for it.
Mine is one touch open and close with auto close on engine shut off so you don't forget and get rain inside.
Old 10-19-2006, 09:33 AM   #54
littlecarlove
Drives: Want a Yaris
Hello new member here - I’ve lurked for a day and was blown away by Violin’s
sunroof install. Dude, you are my hero. The job looks factory. Nicely done.
Hays
littlecarlove is offline   Reply With Quote
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
