#37 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
The TOYOTA parts department . Some are cheaper than others . Sometimes they'll match other parts department prices . Can do it over the phone . One time they gave us free washers with the oil filters at $3.50 each . Depends on what kind of day they had or whom waits on you . Good Luck .
#38 |
2008 YARIS sedan : 3 qts. and 22 ounces of SHELL conventional and new TOYO oil filter on 7/03 . Decided to pour the used oil from the pan and oil filter into empty 4 quart oil jug . There was little over 3 quarts in it . Figure around 3/4 quart of oil remains in the engine .
#39 |
2010 3 door : 3 qts. + 22 ounces SHELL 5w-30 dino and new TOYO oil filter on 7/04 .
#40 |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
Mobile 1 full synthetic 5w30 and a genuine Toyota filter. Oh and I get 2 filters for $10
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
#41 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Mobil1 5W-30 Extended Performance and a K&N Gold oil filter for another 15k mile drain interval. Nothing on the magnetic drain plug.
Also changed the transmission fluid for the 2nd time, again with Redline MT-90. Good for another 50k miles.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#42 |
![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
#43 | |
Drives: 07 sedan Join Date: Mar 2010
#44 |
#45 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
[QUOTE=Ryude;489025]Toyota recently released a press note saying that over the next year they will start to recommend 0w-20 synthetic oil across several models, due to lower emissions and higher efficiency. I wonder if the yaris will be one of them?[/QUOTE
They can recommend all they want!...my manuel and oil cap states 5w-30 and thats exactly what will go into the little dude!.Sounds as if the illusterious EPA is at it again with their rediculous standards.0w-20,please....more efficient,less emissions ![]() ![]() !.Gee,all that crap THEY have been mandating for decades apparently isn't working if we still have "problems".They should be putting regs on Volcanos,their private jets etc,etc,etc,![]() ![]() ![]()
#46 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
hey, if toyota can recommend 0w-20, i don't see anything wrong with putting it in my yaris. if there's an added benefit for fuel economy and emissions, so be it. that's what i'm going to be using.
#47 |
we picked up 4 TOYOTA ( Denso ) oil filters at $3.50 each excluding tax . Didn't give us free washers this time
#48 |
Tw200--excellent!
Don't believe everything they print 1812.....it isn't beneficial to your engine.
#49 | |
http://inlinethumb62.webshots.com/43...600x600Q85.jpg from the picture i provided above, my plug looks like that except without that silver washer... |
#50 |
yes , there's a washer needed for a better seal and easier removal of the drain plug . There are plastic and paper like washers available . I've been using the pressed paper washers . Can be used a few times .
| preformance air filter and oil change? | JapRulezz | DIY / Maintenance / Service | 10 | 12-14-2009 08:24 AM |
| service maintance light | io3 | Yaris TS Talk | 11 | 09-22-2009 03:03 PM |
| Oil change time intervals | PaidTimeOff | DIY / Maintenance / Service | 17 | 01-29-2009 07:14 PM |
| How often do I need to change my synthetic oil? | hans_fh | DIY / Maintenance / Service | 21 | 08-20-2007 05:08 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
