Old 07-24-2010, 03:58 AM   #1
fluke_boy
Drives: 2010 Yaris 3 dr hb
When I first got mine from the dealer I noticed the low tire pressure light was on. I pulled over and scanned the owners manual and found out what the low tire pressure light meant as I had no idea at first. Pumped it up to 32 and it has stayed that way ever since. I guess I'll try 35 - 36 for the 15" when I next gas up.
fluke_boy is offline   Reply With Quote
Old 07-24-2010, 09:22 AM   #2
detroiter
detroiter's Avatar
You guys running 60 psi must have roads from the Kingdom of Heaven or something. No way possible you would survive Michigan roads with that setting.
I was running 44 psi and now I'm at 33 psi. The ride is much more comfortable and
much, much smoother. The bumps are alot less jarring as well.
Old 07-24-2010, 11:38 AM   #3
Hershey
same here .
Old 07-25-2010, 12:37 AM   #4
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
38F and 34R. Thats what give me the best feel.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 08-01-2010, 01:44 AM   #5
djct_watt
Drives: 2010 NCP91 5spd
Wow, with that attitude, you must be the bell of the ball. . . ever try making a point and use arguments or is that beyond your comprehension?
Here's some PHOTO evidence for you smart guy. . .
Better yet, take your car to an autocross and bring some paint with you. Paint a white line across your sidewall and over your tread and drive. Now try adjusting your tire pressure. You'll notice that with higher pressure, less of the white line on the sidewall gets rubbed off. Tire pressure is real, and waving around a BS flag at other people rather than arguing, no wonder you have no idea about it.
djct_watt is offline   Reply With Quote
Old 08-01-2010, 01:45 AM   #6
djct_watt
^ white shoe polish also works
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 09:25 PM
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
2008 Yaris with Tire Pressure Sensors nsmitchell General Yaris / Vitz Discussion 2 08-23-2007 11:34 AM
FS: Stock 15" RE92 tire GabL Items for Sale by private party 9 07-02-2007 02:20 AM
