#1 | |
Yes. Just pull straight back starting with the bottom corners.
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Thanks Scott , this Forum is a vital necessity. Thanks to all.
#3 |
Tw200--excellent!
I haven't started disassembly yet. Any clue as to why the mechanism / cable maufunctions ?. Is there a screw that needs a bit of lock tight applied?. TIA
#4 |
No. The cable carrier assembly just snaps into place. The issue is that if the cable or what it drives binds and you force the cable, you pop the carrier out.
#5 |
Tw200--excellent!
What the heck , the print on my last post is micro???.
#6 |
Tw200--excellent!
Understood , thank you. When I eventually get too this , I'll look for binding points / lube points.
#7 |
Drives: 2007 Yaris Sedan Join Date: Oct 2016
Thanks everyone for the help and pictures. My issue ended up being the actual flap being stuck and not allowing it to move. Taking out the glove box, following the cable to figure out where the mechanism was and moving it manually cleared up whatever gunk had been accumulating and allowed the dial to move normally. Attached some pictures of that in case anyone was interested.IMG_0380.JPGIMG_0381.JPG
#8 |
Drives: Toyota Yaris HB (Vitz) Join Date: Aug 2017
Thanks a lot!! You have saved me my money and time at the garage.
Today I did it and only took 5 - 10 mins. |
#9 |
Drives: 2007 yaris 1.5 Join Date: Jun 2015
I’ve had this problem now for a while ...I HOPE THIS HELPS!!!
Inside my glove compartment where the flap is for the vent , it had a wiring harness cable that fell in front of the flap ... when the glove box is closed it was pushing against the wires that fell In front of the vent flap... Try opening the glove box and then try to flip the vent ... if it flips easy , pop the glove box out and check to see if there is anything impending the vent . That was my fix for a tight vent cable... |
#10 |
Drives: 2008 Yaris Join Date: Jun 2025
Old post but signed up to say it's still helping people.
Just fixed my partner's 2008 Yaris with 39k miles on it. Local garage quoted me almost £200 as they said it was over 2 hours of work. |
| I broke my fan switch... HELP | *MAD DOG* | DIY / Maintenance / Service | 10 | 07-23-2009 09:47 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
