Old 11-22-2010, 07:31 PM   #37
Awesome!
Edit: wait, today at 10 or next monday at 10 LOL.
Old 11-22-2010, 07:42 PM   #38
H3LlIoN
Drives: '09 Yarrrr hatch
Next Monday...couldn't get me in before then b/c of holiday.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 05-17-2016, 09:20 PM   #39
Dr.DevILL
Drives: 2010 Yaris LB
this is hella old and I feel like a scrub responding, but I'm in the hole on my yaris, and it definitely needs some serious upgrades if I'm going to have it for such a long time
Dr.DevILL is offline   Reply With Quote
Old 05-20-2016, 12:15 AM   #40
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You can purchase JUN cams directly and save easily several hundred bucks. You could also contact Web Cams to see about regrinds.
Sent from m-o-b-i-l-e
Old 05-21-2016, 04:40 AM   #41
rabbito
rabbito's Avatar
my cousin has them on
his yaris sedan....rpm just jumps with the car..hp gain is pretty high too but its way too much money for me(broke ass)...he also added piggy back ecu with E85 conversion..$1600 is worth that hp..😃😃😃😃😃😃
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 01-03-2017, 06:33 PM   #42
Yargh-Is
Drives: 2009 Yaris HB
JUN Quality...Defective and Unfinished
I have been doing some massive mods to my 1NZ-FE on my 2009 3DR Yaris, including the latest addition...JUN high lift camshafts. However what I received in the mail was two JUN camshafts that are defective/unfinished. Check out the pics...has anyone else had this experience with JUN. The mechanic at JUN told the distributor I purchased through that these are good to go at "high RPM." Many of my motor head friends and myself think that is a joke...these definitely need MORE WORK...unfinished edges, and ramps not even the same width!!
Looking forward to hearing what some of you think.
Yargh-Is is offline   Reply With Quote
Old 01-03-2017, 06:51 PM   #43
Yargh-Is
Old 01-09-2017, 10:33 PM   #44
The just look like they're shitty castings. You can clean up the side with a file or small sanding wheel.
Old 01-09-2017, 11:39 PM   #45
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
JUN Releases Camshafts for the 1NZ-FE
Put them back on the box and take them back where you buy them ... FFS 1635$ priced cams should be billet pipe cams !
KimmoKekki is offline   Reply With Quote
Old 01-10-2017, 12:16 AM   #46
Jason@SportsCar
That is not how mine looked. The machining and finish of the metal looks way off. Certainly looks like those missed a step in production. I would send them back.
Old 01-10-2017, 08:00 AM   #47
fnkngrv
fnkngrv's Avatar
Yup....not acceptable. They need to go back.
Old 01-10-2017, 01:00 PM   #48
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Something's wrong. That looks like a failing project in high school metal shop. Advanced class perhaps but still failing grade.
Old 01-10-2017, 01:10 PM   #49
Jason@SportsCar
I dont think I have a closeup, but I have a couple of pics. Got mine back in 2012.
Old 01-10-2017, 02:08 PM   #50
Yargh-Is
Awesome guys!
I appreciate the input. RHDJapan (a distributor for JUN) is fighting me on this. I already submitted dispute for transaction and awaiting to hear back.
Thank you for providing your input and pictures to match. They should definitely assist in the dispute.
Once this gets resolved and I am finished with the mods, I will provide some pics of the rebuild, etc. Main mods include: Blitz supercharger, CP pistons, BC rods and springs, JUN camshafts obviously, 1ZZ injectors, larger diameter throttle body, DC exhaust header, K&N cold air intake, NST pulleys, Clutchmasters light weight flywheel & clutch, Tanabe strut tower and stabilizer bar, MagnaFlow catalytic convertor, TRD sports exhaust, Mishimoto oil cooler. I am sure I am missing a few, but you get the idea.
Thanks again guys, to be continued...
Old 01-10-2017, 03:20 PM   #51
Jason@SportsCar
Originally Posted by Yargh-Is View Post
Awesome guys!
Should be a rocket. Double check your pistons compression ratio before you do final assembly, my CP's were low.
Old 01-22-2017, 09:40 AM   #52
Yargh-Is
Thanks for the heads up Jason, will do!
Old 01-23-2017, 08:28 PM   #53
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Holy cow you spared no expense on this build. I'd love to see the dyno numbers
