Old 10-28-2010, 01:21 PM   #1
Hershey
Just checked our 2010 3 door for the leak and more oil had gathered on my finger tips from the gasket . Recleaned the area with paper towels and windex for next physical exam . I also looked at the rest of the engine and it's clean as it can be .
Old 10-30-2010, 07:47 PM   #2
Hershey
I found another 2008 3 door with the same leak at a private dealer . The YARIS was originally a rental at a TOYOTA dealer . The car has 47,000 plus miles . The salesman let me look at the car and I then showed him the oil and oil residue that had gathered on the head cylinder gasket . We had the sedan and told him of the head gasket being replaced under warranty . I then showed him where and how to find the leak . Took him a few tries , but he finally got the oil and residue on his fingers . Said he would show and tell their mechanics of the oil leak and possibly get the H.C.G. replaced under the TOYOTA warranty . I'll be stopping by on occasion to see how they make out with it . Not all that far away .
Old 10-31-2010, 08:01 AM   #3
krolos
Drives: 2008 yaris sedan
You come up with some hard proof that all these cars at the dealer lots
got oil leaks that will be one thing, until then I think this is nothing but
stories your are posting, anyone else on here dont believe this .
krolos is offline   Reply With Quote
Old 10-30-2010, 07:49 PM   #4
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Oh no, is this looking like an all yaris problem? Do you think toyota will recall because of this?
Twistoffate0817 is offline   Reply With Quote
Old 10-30-2010, 07:52 PM   #5
Hershey
We're trying to get TOYOTA to take notice . They're not all that cooperative . Time will tell .
Old 10-30-2010, 08:08 PM   #6
Hershey
That's 9 YARIS so far . That includes our 2008 sedan ( now fixed ) and 2010 3 door ( still leaks ) plus our friends 2010 3 door that still leaks . It's been 5 2008s and 4 2010s with mileage from 3,000 > 48,000 miles on the odometer . We plan to check on others as they pop up on dealer lots . Haven't had the chance to check out any 2007s or 2009s .
Old 10-30-2010, 08:12 PM   #7
1stToyota
1stToyota's Avatar
on the research skillz, but it sounds like lots of trouble...I think I'd just buy a different car
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-30-2010, 08:42 PM   #8
Hershey
No biggie , these cars are usually on our way to shop or just going out for a cruise ( 38+ m.p.g. ). Would consider a new YARIS , but not until this issue is addressed by the highest levels in JAPAN and here .
Old 10-30-2010, 09:02 PM   #9
Hershey
We were going to trade in our 2010 3 door with the oil leak in for the 2010 5 door with 3,500 mis. and the CERTIFIED 7 year / 100,000 mile warranty along with the 2.9% financing for 5 years through TOYOTA , but when I discovered the same oil leak for the 5 door it put an end to that . Why buy another 2010 with the same oil leak that would need to go under the wrench . Might as well keep our 2010 and get that fixed under warranty . Plus we're nearly over with the loan with our 2010 . We're trying to get TOYOTA to give us the 7 year / 100,000 mile warranty for the 2008 and 2010 for free after both head cylinder gaskets are replaced . So far , no luck .
Old 10-31-2010, 12:18 AM   #10
krusty
krusty's Avatar
Drives: 2010 Yaris ce
I think you people are being too overly critical of the products Toyota is putting out. If all cars are supposed to be perfect they wouldn't come with a warranty. Anything mass produced can have flaws and all auto manufactures have the same sorts of problems. Toyota does a better job then most auto manufactures at addressing imperfections in there products.
krusty is offline   Reply With Quote
Old 10-31-2010, 09:41 AM   #11
sickpuppy1
Drives: 2010 Yaris Sedan
No, I dont think its BS at all. I could see a gasket mfg having a process of cutting gaskets and then an arm/pincher picks up the gasket by the corner and puts it onto a spindle or rack and when it does so it pinches the corner of the gasket. Now that spot is a couple of mm thinner than the rest. Ya know, just some simple mechanical process that has made a fault somewhere and now the gasket seeps. I guess my thoughts are, how much does it leak and will it get worse? And of course how much does it bug ya? I guess on cars this new it should not happen, but on cars that are older I almost expect it.
Old 10-31-2010, 11:45 AM   #12
Hershey
What more proof do you need ? We've posted pictures of the leak and the worksheet from the dealership that shows the replacement of the head gasket . When we decide to get the 2010 head cylinder gasket replaced we'll post the worksheet for that . Take it or leave it .
Old 10-31-2010, 01:09 PM   #13
Hershey
GEDC0136.jpg Here's the pics AGAIN . The top is the 2008 sedan when I found the oil on 3/18/2010 with 17,893 miles and below is the 2010 3 door with 3,567 miles found the same day . This means the oil was leaking long before I discovered it . Oil ran all the way down the back of the block to the top of the oil pan of the 2008 . The 2010 didn't reach that far , but close . The other pic below is of the exposed part of the head cylinder gasket of the #1 cylinder of where the oil leaks from and under that is a picture of what it can most likely lead to at 102,000 miles when your WARRANTY has runout . The area CIRCLED in RED is where the oil leaks from the gasket . Your car , your call .
Old 10-31-2010, 02:37 PM   #14
yaris2010RS
yaris2010RS's Avatar
so i finally checked mine, i have over 30,000km on my 2010 and no oil leak, i took the engine cover right off and felt all around and used a mirror and my engie is clean! thank God, lol. that being said my car was built 11/09 and the vin starts with JDT (meaning built in japan) i believe this issue could exsist but that shows north americans shotty worksnamship.
Old 10-31-2010, 03:52 PM   #15
Flipper_1938
Flipper_1938's Avatar
Old 10-31-2010, 03:50 PM   #16
Hershey
Ours were built in JAPAN . Why remove the engine cover , no need for that . You may be looking in the wrong spot . It's not the valve cover gasket , it's the head cylinder gasket that's further down . Hopefully I'm wrong about your car .
Old 10-31-2010, 03:53 PM   #17
Hershey
There are no oil leaks from our valve covers . I've inspected those very thoroughly on many occasions .
Old 10-31-2010, 03:54 PM   #18
Hershey
Yes , all 1.5 ltr. YARIS are made in JAPAN for NORTH AMERICA .
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 02:48 PM
