Old 05-15-2017, 07:32 PM   #37
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Ok thank u
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 05-16-2017, 09:31 AM   #38
Yaris874
Yaris874's Avatar
Wat about the seatbelt light will stay on two or is a away to connect the seatbelt sensor
Old 05-16-2017, 12:28 PM   #39
David C
Drives: White '07 3dr LB
RABBIT SEAT IN YARIS!!!!
I cut off a seat harness connector from a scrap Yaris at the junkyard and wired the seat position sensor to it, then used a 400 ohm resistor for the seat belt buckle wires. Plug the newly hacked seat harness into the car harness and done. Car will think your seatbelt is always fasten and that your seat is at the most forward position. My stock belt male buckle was fitting perfectly into the VW seat female buckle.
You could also get a spare male buckle and leave it into the female buckle of the Yaris stock harness, plug it to to car harness and leave it under the seat along with the position sensor.
David C is offline   Reply With Quote
Old 05-16-2017, 12:41 PM   #40
Yaris874
Yaris874's Avatar
Yea mine 2 fit rite in the vw seatbelt thank for all the Info. Wat about the passenger seat that can't be done rite because off the airbag sensor when the passenger seats
Old 05-16-2017, 04:35 PM   #41
David C
CTScott made a bypass module to plug in the passenger side car harness that emulates the weight sensor to trick the car into either ON or OFF for the passenger. I've PM'd him about it when I did the swap in my car, but he hasn't gotten back to me to this day. He made a bunch of them and sold them trough private parties and micro image back then, but I couldn't find one for sale anymore. There was one for sale in the forum classified, but that's long gone.
Try to ask CTScott directly to see if he could make you one or if he still have one on hand. I'd be interested into getting one too.
Old 05-17-2017, 12:48 PM   #42
Yaris874
Yaris874's Avatar
Oh ok I message him about something couple month ago but no answer so am not even goin to try I probably take the seat apart and see how that sensor work I let u know how e goes
Old 05-17-2017, 06:02 PM   #43
David C
Look around on the forum, someone already took it apart and the end result was that unless you could mount them back on the new seat (requires upholstery and metal fab), you can't bypass them since it's a canbus signal.
I sent him another pm yesterday and still no answer.
Old 05-17-2017, 07:18 PM   #44
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Last he checked in, CT indicated he'd been very busy with work...
On Instagram
On Wheelwell
Old 05-17-2017, 08:22 PM   #45
David C
Thanks for sharing.
wtb: racing seat bracket for yaris hatchback vten Willing to Buy by private party 1 08-03-2009 09:51 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
