Old 12-29-2010, 04:00 PM   #37
Originally Posted by Judas Iscariot View Post
brown and green wire on driver side 12.88
white wire nothing... i am testing each wire to a ground right?
Yes. Also measure each with the headlights on and with high beam.
Old 12-29-2010, 04:02 PM   #38
Judas Iscariot
Drives: 2008 Yaris HB
i know you said one side will do but i tested the pasenger side too and the only one that reads it the black one, again 12.88
Judas Iscariot is offline   Reply With Quote
Old 12-29-2010, 04:02 PM   #39
Judas Iscariot
going to test on and hi-beam now
Old 12-29-2010, 04:36 PM   #40
Judas Iscariot
ok the picture is the wires and locations
Driver Side
----- White green Brown
off - 14 -- 14 -- 14
low 5 -- .4 -- 9
hi -- 4 -- 9 -- .5
Pass Side
----- Black Blue Brown
off - 14 -- 12 -- 12
low - 14 -- .3 - .3
hi -- 14 -- 8.77 -- .67
hoipe the chart is useful, Thanks for helping. i can't say that enough CT
Old 12-29-2010, 05:20 PM   #41
Judas Iscariot
I forgot o load the picture. Sorry
Old 12-29-2010, 05:56 PM   #42
No problem. Try pulling just the passenger bulb and then turning on the headlights to see what the driver's side bulb does in the three states with the other removed.
Old 12-30-2010, 09:55 AM   #43
Judas Iscariot
gonna do that on my lunch break...
here is the picture
Old 12-30-2010, 03:26 PM   #44
Judas Iscariot
these are the numbers taken with the opposite side detached. sorry it took all day.
Driver Side
off - 11.2 -- 11.2 -- 11.2
low .22 -- .22 -- .22
hi -- .02 -- .02 -- .02
Pass Side
off - 13.8 -- 13.8 -- 13.8
low - 13.7 -- 13.7 - 13.7
hi -- 13.4 -- 13.3 -- .47
Old 12-30-2010, 03:27 PM   #45
Judas Iscariot
oh and the white wire is actually grey
Old 12-30-2010, 05:16 PM   #46
Hmmmmmm. I am still reallllly thinking that the H-LP/AMT Relay might be the culprit.
With the bulbs both in, the charts should look like the following:
Driver Side
----- Grey Green Brown
off - 12 -- 12 -- 12
low 12 -- 12 -- .4
hi -- 12 -- .7 -- 12
Pass Side
low - 12 -- .4 - 12
hi -- 12 -- 12 -- .7
On yours, the low beam power is not being properly switched. On a working car, if you pull the relay, the high beams will work, but the low beams will not turn on at all (which is basically what you are seeing).
One last thing to try before replacing the relay is to unplug the DRL module's connector.
Old 12-30-2010, 06:44 PM   #47
Judas Iscariot
I disconnected the drl box and nothing. If Toyota is open tomorrow I will go get a relay. Or auto zOne. Some place like that hopefully has it
Old 12-30-2010, 07:12 PM   #48
If you can find a way to jump the two large blade slots together, while the headlights are on, and on low beam, you can do a final check to make sure that that relay is truly bad (since it is a $30+ relay).
Old 12-30-2010, 08:07 PM   #49
Judas Iscariot
Wow. Sparks! Lol I'm ok. But the headlight stalk was in off position and when I connected the two the lights came on. That was suprising! But it didn't fix it. Every time I think it will work It doesnt. Oh well. What's next?
Old 12-30-2010, 08:16 PM   #50
Judas Iscariot
Another thing. I went put and pulled the relay. And the high beams do still come on, but the driver side lamp is still turning on both filaments. And they are still dim, really dim.
Old 12-30-2010, 08:25 PM   #51
Judas Iscariot
ugly....
Old 12-30-2010, 10:51 PM   #52
I meant to say ONLY connect the jumper with the headlight stalk on and in low beams. In that state, did the lights come on?
Old 01-05-2011, 12:20 PM   #53
Judas Iscariot
i fixed it! lol, Thanks CT.... all i had to do was total it. problem solved.
Old 01-05-2011, 12:26 PM   #54
No way! There seems to be way too much of that going around lately.
aftermarket headlights be_ha Cosmetic Modifications (Exterior/Interior) 0 10-03-2010 03:06 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
