Old 11-19-2011, 11:16 PM   #37
Originally Posted by Chuckinator View Post
Hey CTScott, I'm interested in installing cruise control on my 2007 automatic sedan. Do you happen to have any parts left for sale? I don't have anything right now, so I believe I would need the stalk, stalk wire, and the necessary pins.
I'm also interested in your custom indicator, if you are still producing those.
Yes. I still have all of the parts available. I will PM you with details on what you need for your car.
Old 11-21-2011, 07:41 PM   #38
SimTronik
Machinist
Drives: Yaris sedan 2010
I don't have any cruise control on my car is this all i need?
I'd like one and all i need to make it work. Can you PM details, i'll send you a payment via paypal.
Thanks.
I'M from Quebec, canada
SimTronik is offline   Reply With Quote
Old 11-21-2011, 09:26 PM   #39
Thanks.
PM sent.
Old 11-22-2011, 05:40 PM   #40
Grimsby53
Drives: 07 Yaris 3dr MT (bayou blue)
I'm also interested in a turn-key kit for an 07 3-dr hatch, manual transmission.
PM me with price, and payment details, please.
Grimsby53 is offline   Reply With Quote
Old 11-30-2011, 09:46 PM   #41
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
PM'd
The Spectacle is offline   Reply With Quote
Old 12-01-2011, 07:11 PM   #42
SimTronik
Machinist
I just received it.
I don't understand the Yaris w/ power or without part in the manual. Can you explain? Thx.
Old 12-01-2011, 07:42 PM   #43
I just received it.
That is with or without the factory power package, which includes power locks and windows.
Old 12-01-2011, 08:02 PM   #44
SimTronik
Machinist
Oh great i have all that. Hope it make the install easier :D
Old 12-01-2011, 08:08 PM   #45
SimTronik
Machinist
So i'm missing: Connector D3 Pins, quantity 2 (82998-12870) and Lower Steering wheel Boss (cover) (with the hole already in it for the cruise stalk {If you
don’t wish to drill the exiting one}):45184-52130-B0 and ¼” Ring terminal for 18-22 AWG wire (if required to terminate added D3 ground pin).
If i get it right...
I own a Yaris sedan 2010 w/ power.
(ok ok i could drill the existing steering)
Old 12-01-2011, 08:28 PM   #46
Did you verify that the D3 pins are not present? A 2010 Sedan with power should have them.
Old 12-01-2011, 08:35 PM   #47
SimTronik
Machinist
Oh ok, not checked yet.
Removing the wheel looks like a hard job for a beginner :S
Old 12-01-2011, 08:37 PM   #48
You only have to remove the wheel if you are replacing the lower boss with the pre-holed one. You can mark and drill your existing one in place.
Old 12-01-2011, 10:46 PM   #49
SimTronik
Machinist
Really! I was planing to drill the hole after all. I read all the manual pdf and i was lost at the wheel and air bag removal and i though it was kinda risky. But it seems more plug n play. Can you guide me to what part of the installation manual is pertinent for me? Thanks a lot!
Old 12-01-2011, 10:54 PM   #50
Section 1.1 for the airbag removal
Section 1.3 for the lower boss hole drilling
Section 1.4 up to 1.4.2 for the stalk and wire installation
Section 1.5 for re-installing the airbag
Section 2.1 to verify the presence of the connector D3 pins
Old 12-02-2011, 06:54 AM   #51
SimTronik
Machinist
Perfect thanks! Any tips what to avoid with the airbag?
Old 12-02-2011, 07:33 AM   #52
Just make sure that you disconnect the negative battery terminal and wait a couple of minutes before disconnecting the airbag, and when you remove it, set it down on its frame, rather than on the Toyota logo.
Old 12-03-2011, 05:34 PM   #53
SimTronik
Machinist
Everything is plugged in and back on its place but i cant remove the steering colum cover. i think its because the wheel is in place? So i cant check for the d3 pins. Can i just road test it lol? or it is risky?
Old 12-03-2011, 05:43 PM   #54
You can just road test it, or better yet, turn the ignition to ON, press the on/off on the stalk, and see if the indicator comes on.
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
