Old 01-12-2013, 06:41 PM   #37
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Those are some crazy eyeballs!
Old 01-15-2013, 05:00 PM   #38
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
ALWAYS gap your plugs. It's silly not to do that.
Why do NGK say that IridiumIX should not be gapped? tip is so fine... you can very easily damage it! I could do more harm than good..
Just lookin for the ''good'' answer.
thx for inputs!
maxthehax is offline   Reply With Quote
Old 01-15-2013, 06:52 PM   #39
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
thx for inputs!
true, you aren't supposed to gap iridium and many of the higher grade plugs. The tips should be already gaped from the factory, but it is still good to check them to be sure they are not bent. There is not much point in trying to bent them back due the the high risk of it just braking. typically if you get new plugs, open the box and notice that the protective sheath of the threaded end is either damaged or missing, you should either not get them or replace them with some the the parts guys didn't throw around.
fancy plug shouldn't need to have the gap adjusted
basically, no sheath, no purchase
bad gap, pointless the re-gap
Old 01-15-2013, 07:45 PM   #40
^ agreed. I meant more that I would measure them before installing, as they are not always perfect. Install a different one if the gap is incorrect. Little bit of old school thinking got in my way -- sorry about that.
Old 01-15-2013, 10:47 PM   #41
Golddeenoh
Golddeenoh's Avatar
^ i'm just glad that i get to share what a learned in college lest semester :D
Old 02-23-2013, 09:16 AM   #42
maxthehax
maxthehax's Avatar
Okai thanks for clearing that up :P
Turbo Toyota FT-86 G Sport Concept Car revealed at TAS! Mess11 Off-topic / Other Cars / Everything else Discussions 20 01-23-2010 11:34 AM
Yaris and Echo short shifters sale, $30 off! TWM Performance TWM Performance 8 11-17-2008 02:23 PM
