Old 01-06-2014, 06:10 AM   #37
Originally Posted by jackab View Post
The Rostra instructions said to splice the two wires from the clutch switch to the two wires leading to the A29 connector. The connector was taped up out of the way and was not connected to anything. The CC should work without the clutch switch installed, so I disconnected those wires. Still, the dash CC indicator light comes on and CC doesn't work. I will next take the airbag off and make sure everything is done right there, but it's so simple that even I should be able to get it right.
I installed one of the old style Rostra CC units in my 2010 Yaris, and it works well. It cost a lot more and is more elaborate. The 2011 Yaris belongs to my wife. Her knee is hurting her, and the cruise control helps a lot, so we need to get it going. (You probably didn't need to know all that.)
Thanks for all your time and help.
Bill Foreman
Moab, UT
Mountain Biking Capitol
The CC will not work unless the clutch switch is indeed connected properly. It is a normally closed switch and the ECM needs to see that connection and will abort cruise when it is not.
Old 01-07-2014, 10:22 PM   #38
jackab
Drives: 2011 Yaris Hatchback
You are my hero. It was the clutch switch hookup. It is pretty difficult to work under the dash, and I suppose I didn't make one of the clutch switch connections correctly. This time, I took the seat out so it was easier to work and made the two connections work. I screwed up one to my splicers and soldered the connection instead. Soldering is actually easier than using the splicers, and it is obvious when it is done right. When I installed the CC in my Yaris, it would work without the clutch switch hooked up. In fact, I saw how the brake switch worked and figured out a way to install a micro switch I had left over from my days as an airplane mechanic instead of buying a Rostra switch.
What other products do you sell besides the CC?
jackab is offline   Reply With Quote
Old 01-09-2014, 12:02 PM   #39
DCYarisGuy
Drives: 2010 2-Door Hatch
Hey I have a base model 2010 Yaris Liftback with A/T. From what I'm gathering from the PDF all I need is the stalk and (if I want) the new boss cover. I won't need to run any wires to the ECU. Is this correct?
Thanks!
DCYarisGuy is offline   Reply With Quote
Old 01-09-2014, 12:05 PM   #40
Thanks!
That is correct.
Old 01-17-2014, 05:40 PM   #41
DCYarisGuy
That is correct.
I purchased the stalk, wires, and mounting screws from CTScott and it took about 30 minutes to install. Working great on my 2010 Yaris hatch! Thanks!
Old 02-26-2014, 08:43 PM   #42
Originally Posted by ZAKU View Post
CTScott, what are your thoughts on these?
http://www.ebay.com/itm/Toyota-Camry...0fa459&vxp=mtr
Cheap Chinese junk?
I'm not sure. I have seen those Chinese clones on ebay, but haven't seen one in person to compare the quality versus OEM.
Old 08-12-2014, 10:42 PM   #43
GAWADE
Drives: 2012 Yaris 4d Auto Coupe
OEM Cruise Control
Mr. Scott,
You are a man of your word and then some!
By far the best simplest installation ever!
I got home late from work, looked over the instructions and thought maybe I should wait when I had more time, it's already dark...
I sat down and really read the instructions and realized I was done after step 2! So went out and did it. The thing that took the longest was finding a T30 to fit. I had a socket set of them but it was to big/short to get all the way in. But once I got one that worked I was off and running!
Great job! Thank you !
Glenn
GAWADE is offline   Reply With Quote
Old 09-04-2014, 10:14 AM   #44
wildwildip
Drives: 2007 3 Dr A/T
A++ product and install manual. Fast shipper of his kit too! Thanks Scott!
wildwildip is offline   Reply With Quote
Old 09-18-2014, 07:27 AM   #45
edmondcenteno
Drives: yaris 2008 sedan
Guys
Does it works for 2008 toyota yaris sedan GCC specification?
Thanks you
edmondcenteno is offline   Reply With Quote
Old 09-18-2014, 07:37 AM   #46
edmondcenteno
Sir,
I have 2008 yaris sedan GCC specification,, does it has Cruise control provision?
Old 09-18-2014, 07:39 AM   #47
Originally Posted by edmondcenteno View Post
Sir,
I don't believe it does. PM me the VIN for you car and I can tell you for sure.
Old 09-20-2014, 10:30 AM   #48
For a 1.3L you are limited to an aftermarket solution.
Old 09-21-2014, 04:24 PM   #49
Eduardo_mty
sorry for my english
Im owned the New 2015 Toyota yaris. And i saw this DIY And i think is possible to do it.
My car is 5 speed manual transmisión, And need to install clutch switch, And stale.
If i upload pictures here, some with knowladge Will helpme.
Eduardo_mty is offline   Reply With Quote
Old 09-21-2014, 06:29 PM   #50
Eduardo_mty
This is one pictures from steering wheel
I think the White connector(unpluged) Will be where i will connect the stalk
Old 12-13-2014, 12:35 PM   #51
mostafa67
Drives: Toyta Yaris sedan
need help :)
hello everybody :) am Mostafa From Egypt and I have a Toyota Yaris 4 doors sedan 1.3 litres with engine 2NZ-FE , i was wondering if my ECU supports this cruise control kit or not and if yes where can i buy it online i mean the link i can but from it and how much is it or where can i buy it from California as there's a friend of mine there can buy it for me and send it and the ECU code is (89661-52B70 ) sorry for talking too much and thanks for help :)
mostafa67 is offline   Reply With Quote
Old 12-13-2014, 03:04 PM   #52
Is there a link with price info for the CC for a '08 Yaris w/a manual trans? Wouldn't mind buying one from Scott in the spring
Old 12-13-2014, 03:11 PM   #53
Shoot me a PM when you are ready. I don't post pricing, as each time I buy a batch of parts the price seems to change one way or the other.
Old 12-13-2014, 11:44 PM   #54
Thanks Scott, I'll PM you in the spring
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
