Old 05-04-2011, 10:20 AM   #37
That part with the stuck bolt is called the "block, fusible link" (82620-52050). It's only $12 from the dealer (the clamp is a separate part, and that is about $20). With the corrosion the bolt and nut may be fused to where they can't be removed without snapping the bolt.
battery, battery terminal, corrosion, duralast, fail
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 03:40 PM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 12:11 PM
