Old 03-14-2007, 01:20 PM   #37
dresden_k
Honda Convert
Drives: NCP91L
Originally Posted by mrrock View Post
I've got the Tanabe NF's and 205/50/16's on BBS and I've had to modify the front inner plastic liner so they don't rub: bent the front and back metal tabs and then used a heat gun to modify the plastic liner at the tabs
Do you guys think that 205/45/16 would rub, with most moderate lowering springs?
dresden_k is offline   Reply With Quote
Old 03-14-2007, 02:41 PM   #38
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
From what I gather, so long as you have the correct offset... for a 6.5" wheel its +40 for a 7" wheel +45, it shldnt rub at all.
Right ?
nurburgring is offline   Reply With Quote
Old 03-14-2007, 03:34 PM   #39
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
No rub
Hey, dresden_k
I drive on 205/45/16 with Tanabe NF210. No rub. Zero problems. I will post new pictures this week so you can check out the lowering situation. I need to clean the outside before posting new pix. Its drives great. I do still need a alignment but that will happen this Saturday. I personally believe that you should always do the alignment after removing the springs.
Rwseattle.
rwseattle is offline   Reply With Quote
Old 03-14-2007, 06:09 PM   #40
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Right ?
I get very minimal rubbing on full suspension compression.
Old 09-20-2007, 10:41 PM   #41
johnnypaseo
Drives: Toyota paseo
hey large ur yaris looks good thinking about getting the spring techs myslef i love the drop. I was just wondering if you had 195's instead of 205's will it still rub in dips and all
Old 09-21-2007, 04:53 AM   #42
blueskana
blueskana's Avatar
Drives: 2007 Yaris LB
My 6.5" +40 with 195 juuuuuuust graze (you can just see road dust being rubbed) on full bumpstop mashing compresion with the wheels turned, though no damage at all. I just mounted some 7" +40 with 205/50 Toyo RA1's and unfortunatly they are tearing my front wheelwells apart and scuffing the tires pretty bad if the wheel is turned and the front end loads up hard. Drop is Tein S.Tech's with cut bumpstops/stock struts. I'm bummed because I was hoping I could get away with the wheels, but it looks like I'll need +45 and removing that area of wheel well liner to clear it 7" wide rims.
Good luck.
blueskana is offline   Reply With Quote
Old 09-22-2007, 03:52 AM   #43
johnnypaseo
really dam the s techs drop the yari really low i guess but thanks for the info
Old 09-22-2007, 04:09 AM   #44
blueskana
blueskana's Avatar
Mind you that's only worst-case-scenario: shocks mashed flat, tires cut hard, no camber adjustments (as 03Z33 has had success running his car hard with +35's, but camber cranked allowing the wheel/tire to slip inside the wheelwells and clear). I hope you find something that works for you.
I'll try and get some +42, 43 and 45's in 7" to test fit soon and let you know how it goes.
Old 09-22-2007, 04:21 AM   #45
johnnypaseo
thanks man i appreceiate the feedback!!!what off set would you recommed for a daily driver is 40 plus ok with 16x7's and how low of a drop is 1.7 ok?
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Got new wheels, tires, and springs installed. largeorangefont Photo-Video-Media Gallery 8 01-22-2007 04:29 PM
Just put my new wheels on Ryosuke Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 07-18-2006 01:04 AM
Lets talk wheels birdy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 80 04-29-2006 01:13 AM
