#1 |
![]() ![]() Drives: Yaris Join Date: Oct 2017
I fixed mine over the weekend. Just loosened both the top and bottom bolts, used a prybar wiith one hand and re-tightened with the other pulling it as hard I could and done.
No more squeaky belt. |
![]() ![]() ![]() ![]() Drives: 2007 2-door hatchback Join Date: Jul 2016
Serpentine belt tension adjustment Toyota Yaris
Overtightening a serpentine belt destroys driven components and idler bearings.
#3 |
Mine has been quite since.
#4 |
![]() ![]() Drives: 07 Yaris Hatch Join Date: Aug 2017
As soon as I went to the Scion 100 amp alternator, mine has quit squealing. The Scion alternator uses a de-coupler pulley, so I think that has something to do with it.
#5 |
![]() ![]() ![]() ![]() ![]() Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Check out this 'interesting' video...
https://www.youtube.com/watch?v=HRrVMtyIqIY When I first got my car, it squealed badly, partially because the previous owner put belt dressing on it. I can confirm that delaying ignition does work, at least for belts that squeak when the engine is first started. It did on mine anyway.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ |
#6 |
![]() Drives: 2010 Yaris 3D LB Join Date: Jun 2010
The smooth side of the belt on mine was shiny probably from slipping. Increasing tension would not fix it. I took the belt out, lightly sanded it (probably 320 grit emory cloth) on the non-ribbed side to take the shine off, and also sanded the smooth pulley to clean it up. It's now completely totally silent for the first time in years.
#7 |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
mine hasn't squeek for yrs now. Just use a good quality belt and tighten it correctly, not too lose cause it'll squeal or not too tight cause it degrades it and wears out pre-mature.
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Squealing Belt | rossman | DIY / Maintenance / Service | 8 | 01-31-2012 01:58 PM |
| Supercharger Belt Slip Possible fix | quemoto | Forced Induction Forum | 20 | 03-04-2011 02:55 PM |
| 2010 Prius brake problems easy fix. best video ever! | dinamix | Off-topic / Other Cars / Everything else Discussions | 6 | 03-14-2010 11:00 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
