Old 07-17-2014, 01:36 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've just realized that up to this point I've been referring to the pinion shaft as the "output" shaft. Now that the output/drive shafts are in the discussion, I should probably stick with "pinion" for the shaft between the input and differential from now on, yes?
Old 07-17-2014, 06:18 PM   #2
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
How can I know the ratios? I would like to recheck the XD gears cuase when I searched the tranny some parts are shared with the corolla but some are unique I think the first gear of the XD is one of them. I have still not assembled the tranny yet so id you guys need any info or pics let me know it's opened and covered in WD40
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 07-18-2014, 10:34 PM   #3
Jerkratt
Jerkratt's Avatar
So going for track use... Swapping XD final drive out of the first Gen would be the way too go?
"It hurts more when its wet"
changing gear from robotic to automatic mariann DIY / Maintenance / Service 13 12-09-2011 06:43 PM
Gear Ratios J_T Performance Modifications 1 06-16-2011 12:31 AM
Changing Gear Oil Of the C160 Parmas DIY / Maintenance / Service 12 01-20-2011 02:44 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Gear Ratios? aephilli DIY / Maintenance / Service 3 04-12-2007 05:38 PM
