Old 09-29-2011, 01:42 PM   #37
Nas_RS
Vitz_RS
Drives: Toyota Vitz RS NCP91
Hello guys, the swapping parts have already been done by the mechanic, with the help of Scott i am going to do it myself to ensure, i will buy or get a coil pack and check it.
I will try to test also the continuity of the wires #3 with multimeter <what you say Scott?>
If still not good i will buy an ECM link below, either programmed it for my car or swap the DENSO Chip to mine and get it work <Your advise Scott Please...>
http://cgi.ebay.com/ebaymotors/ws/eB...4796&viewitem=
Thanks Guys...its about 2 weeks my car is not running...quite discourage :(
Nas_RS is offline   Reply With Quote
Old 09-29-2011, 02:31 PM   #38
You can test the continuity of the #3 coil wire from the ECM Connector C20, pin 83 (circled below) to the dark green wire on the cylinder 3 coil pack connector (C13, pin 3).
The other three wires on the coil pack connector are common with all 4 coils, so you can check continuity between pins 1, 2, and 4 of the cylinder 3 coil pack connector to pins 1, 2 and 4 of another cylinder to make sure that all four wires on cylinder 3 are good.
The ECM in that link is a 52E90, so it won't be programmable for your smart entry, but would have the Denso IC to swap.
Old 09-29-2011, 02:46 PM   #39
Nas_RS
Vitz_RS
Ok Scott for the Green, i got where to check it from pictures.
While for 1,2 & 4 you tell me to check to another cylinder on the entry of the ECM (the first picture plug)
Old 09-29-2011, 02:52 PM   #40
Yes. For the 1 (light green), 2 (yellow) and 4 (white with black stripe) pins you check from the cylinder 3 connector to the same position on another cylinder connector.
Old 09-29-2011, 02:55 PM   #41
Nas_RS
Vitz_RS
Ok thanks and i assume that the engine start must orange, not start the engine
Old 09-29-2011, 03:11 PM   #42
Nas_RS
Vitz_RS
Going for a ECM 52E90...due to the ECM 52B10 not getting on the market, due to Japan Radiation issue
Old 09-29-2011, 04:16 PM   #43
Yes. Engine must be off when testing continuity and it would not be a bad idea to also disconnect the negative battery terminal as well.
Old 09-29-2011, 11:08 PM   #44
Nas_RS
Vitz_RS
Thanks Scoot, I'm going to try that and let you know the outcome
Old 09-30-2011, 07:57 AM   #45
Nas_RS
Vitz_RS
Hello, Scott what happen if i try to merge the wire from cylinder 3 to cylinder 2 which is working. mean get the 2 ignition working on same wire. is it possible?
Old 09-30-2011, 08:15 AM   #46
That would not be a good idea. That would make cylinder 3 fire at the wrong time.
Old 09-30-2011, 08:40 AM   #47
Nas_RS
Vitz_RS
ok thanks dude, i wont got for merging wires.
Does the cylinder work across, while swapping the coil pack, can i take from any.
Is there a pairing (Cylinder 1:3, Cylinder 2:4)
Old 09-30-2011, 08:44 AM   #48
They fire sequentially, as opposed to in pairs. You can swap it with any other one. The failure code should change from P0353 to P0351, P0352, or P0354 if the coil is bad, and depending on which cylinder gets the bad one.
Old 09-30-2011, 10:35 AM   #49
Nas_RS
Vitz_RS
OK scotts, i shall try that tomorrow GMT+4, hope that's going work.
The idea of merging the wires was just to see what happen, if all cylinders work and no issues, which may conclude their is an issue on the wiring of cylinder 3 or the ECM itself
Old 09-30-2011, 11:01 AM   #50
tropicalrs
Drives: vitz RS
Nas have u been able to fix the problem?
tropicalrs is offline   Reply With Quote
Old 09-30-2011, 11:47 AM   #51
Nas_RS
Vitz_RS
Nope i am going to try all these steps tomorrow (with Scott helpful info)
Old 09-30-2011, 01:42 PM   #52
tropicalrs
Drives: vitz RS
ecu
here it is Nas
http://www.myjapanbrand.com/db/detail.php
Connects2 UNI-IR Universal Infrared Steering Wheel Control Interface rognewton In Car Entertainment + Electronics (audio / video / alarm) 0 05-04-2011 09:42 AM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
