Old 07-06-2018, 08:36 PM   #37
Arod0610
Drives: 2007 yaris
So I just changed the water pump radiator and thermostat and I’m still having overheating problems ... and tips or help I can get is appreciated!!
Arod0610 is offline   Reply With Quote
Old 07-06-2018, 08:59 PM   #38
Define overheating - what are you experiencing? Could be a bad rad cap, could be a faulty coolant temp sensor, could be a blown head gasket etc etc
Old 07-06-2018, 09:35 PM   #39
Arod0610
Drives: 2007 yaris
I can drive the car for about 15-20 minutes before it goes hot also when the ac is on it goes hot faster
Old 07-06-2018, 10:53 PM   #40
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Are you positive you put enough coolant in the car? You might have an airlock. I've done many coolant changes and the Yaris purges air pretty easily if you have enough coolant in the system. If you have a smart phone you can pick up Torque Pro app and a cheap OBD2 bluetooth adapter (everything for under $20.00) and monitor coolant temps. That's what I use so as I approach ~180 F, I start feeling the upper rad hose for heat to see that the thermostat is opening.
Old 07-07-2018, 01:01 AM   #41
Arod0610
Drives: 2007 yaris
yeah I’m positive it has enough coolant... just today the coolant was spilling threw the resivor tank
Old 07-07-2018, 06:34 AM   #42
stykerdk
Yaris Hybrid Limited 2015
And the electric fan is running, it should run when the AC is on.
And on mine 2013 the rpm on the fan increases when the coolant get hot.
So it could be the thermoswitch on the coolant.
C-HR 1,8 Hybrid premium 2020
Old 07-07-2018, 08:07 AM   #43
Pull the rad cap while cold, start the engine and let it heat up. If start seeing bubbles you have a head gasket leak. Had that happen on an old CRX race car I used to crew for.
Old 07-07-2018, 10:57 AM   #44
Arod0610
Drives: 2007 yaris
I tried the rad cap all I get is a couple air bubbles... could it be a bad thermostat?
Old 07-07-2018, 01:10 PM   #45
hw6515
Drives: 08 Yaris AT, 350Z GT MT
If everything started when you ran the car with low coolant level I think air could be the problem.
Double check all your work and flush the whole system as instructed in the water pump replacement guide.
Properly fill and bleed the air out of the system, use toyota coolant.
hw6515 is offline   Reply With Quote
Old 07-07-2018, 02:09 PM   #46
Arod0610
Drives: 2007 yaris
Got it... thanks for all the help really appreciate it
coolant, heater, overheating, radiator, thermometer
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
ATX temperature overheating? yaryarbing Fuel Economy Forum 7 05-07-2011 09:24 AM
2007 Yaris Door Lock Issue bhola General Yaris / Vitz Discussion 7 10-05-2010 12:01 AM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
