#37 |
Aras, that's the purpose of a dyno session. To tune the motor.
#38 |
Yes really. I wouldn't dyno before, but if it's running good and has decent A/F, why not?
#39 |
LOL
#40 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
Garm.. you have lost it... talking to yourself and responding... wow
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#41 |
omg. LOL. Aras was on here being a goof again.
Yo Mod... um... you can delete mine too!
#42 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Lmao. I think it's fine just the way it is.
#43 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
#44 |
![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
Going to be running 8psi don't want to blow up the engine!
Car seems to be running fine in cold start makes a little bit of a noise not sure wat it is .. And oil pressure is sometimes high around 90-100 psi on throttle but then goes back to normal once car is warm! But everything seems alright I wana dyno before and after just to see results and for other members!
#45 |
Why not do a pull or two, tune the car ON the dyno (really is the best way), then see your final result?
I'm not sure I understand taking two trip to the dyno, but as you wish!
#46 |
That's true I might wait for tune to dyno!
Hey guys last night I installed hks blow off valve and today when I was driving it backfired twice .. Wasn't a loud backfire but is Thai caused by the BOV or which I think is the exhaust valve not closing in time and fuel going into the exhaust? Dont want it to damage the turbo
#47 |
You wont damage the turbo. You need to recerc your bov or you maybe running too rich
#48 |
you need to run the valve recirculated back to the inlet of the turbo. You're venting metered air, so the computer is adding fuel for air that isn't going into the motor when you close the throttle.
#49 |
#50 |
Lol guys I wish that made sense kinda made sense I am thinking of putting the old zage bov on it ran much smoother with it on .. Notices some difference with the hks bov
#51 |
after researching it made more sense!! found this DIY http://www.dsmtuners.com/forums/arti...tion-pipe.html
made more sense.. i will find time to do this and see if it work hopefully will stop backfiring and improve the cars response
#52 |
Goods news my boomslang harness has arrived from microimage thanks garm!! Bad news was messing around with the o2sensor trying to get the signal wire for my afr gauge and for some reason p0032 and p0038 cels have cone up and won't go away when I clear it 2seconds later code came back! I want to get this fixed I don't like it when my check engine light is on!!
#53 |
^ you can't split the wire from your O2 sensor for a gauge. You need separate, dedicated bungs and use two sensors. That's why wideband AFR gauges come with a sensor (they all should, anyway)
#54 |
Thanks for that garm I either blew a fuse or the wire cause it won't go away! But tomorrow I will sort it out!
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| Boosted Yaris Quarter Mile Times | 1.5 | Forced Induction Forum | 0 | 01-03-2010 05:49 PM |
| Yari Boosted, Enge lite... | N3misiS | Forced Induction Forum | 14 | 11-20-2009 07:22 AM |
| Going Boosted | FryGuy | Forced Induction Forum | 53 | 03-01-2009 10:01 PM |
| PE Boosted Yaris Video | jinxor | Forced Induction Forum | 16 | 02-06-2009 02:33 AM |
