#37 |
#38 |
Lalo na pag segunda, unti-untiin mong tapakan yung throttle hanggang umabot sa 4k rpm sabay pasok sa tresera... hehehehehehe!
#39 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
#40 |
#41 |
#42 |
#43 |
![]() ![]() Drives: 2008 yaris Join Date: Mar 2010
C, YES- bolt-on to 1.3L 2nz yaris. ganyan na ganyan yung intake kit ko dati at namana na ngayon ni blessed yaris. Nasa $200+ pa nun ang bili ko from ebay. Ang advantage nito is easy to fit and easy to remove as the design is plug and play.
Kung locally made naman or diy, maraming options..either via PVC tee pipe mod (like exweber/syntax) or via coupling with aluminum tube using the OE MAF mount. I prefer na you score OE maf mount + tube from a junk yaris. Keeping your original behind the trunk and you can put it back during rainy days or sandstorm season. HiH @ricepower ito ba ang disadvantage ng CAI setup dapat lagi maganda ang weather?di pwede sa sandstorm eh dito sa saudi laging sandstorm.wala bang CIA na kahit sandstorm and rainy season wala maging problema? |
#44 |
@Amaze, look forward sa advantage. Kung ang concern mo is yung sandstorm, may DIY dyan. Either balutin mo ng foam yung air intake (e.g ung ginagamit sa window AC) or lagyan mo ng shield during sandstorm.
#45 | |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Apr 2009
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way If everything seems under control, you`re just not going fast enough...
#46 |
tulad ngayon sandstorm na naman, if may time kayo mga kayaris, linisin na agad ang air filter dahil for sure kapal ng buhangin nyan.
#47 |
tol ung filter ko dalawang sandstorm na pinagdaanan diko pa nalilinis, hehehe...
#48 |
Corporate Slave
Drives: 2010 Yaris YX aka "Cutie" Join Date: Oct 2011
Tol dalawa pa lang ba bilang mo??? he he he
Si Vis Pacem Parabellum CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to. Keep your ride rockin and rollin |
#49 |
I mean dalawang heavy sandstorm, hindi pa kasali kung ilang araw ang duration bawat isa, hehehe...
#50 |
#51 | |
#52 | |
![]() ok na brakes pre? wala naman ako narinig nung tinetesting diba?
#53 | |
![]() Drives: Vios/Yaris Join Date: Apr 2012
Yan lang ang disadvantage ng open filter. Why not try the drop in filter ng K&N paps? ) pero naka aftermarket filter ka.Question lang: meron ba dito nag customize ng headers and pipings for Yaris? thanks |
#54 | |
sa question mo sa headers and pipings, wala nito sa riyadhor sa east, (dammam,khobar) naghahanap din kami nyan dati. |
| Any Aftermarket Intakes Yet?!?!?!?! | silverRS | Performance Modifications | 120 | 12-07-2011 06:44 PM |
| Weapon-r sheet metal intakes 1/2 off (almost) | H3LlIoN | Forced Induction Forum | 5 | 11-27-2010 12:21 AM |
| aFe intakes in stock! | cali yaris | Micro Image | 66 | 02-11-2010 04:58 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| air intakes? | SLIK4 | General Yaris / Vitz Discussion | 16 | 05-21-2007 09:34 PM |
