Old 09-22-2012, 05:15 PM   #37
Astroman
Modded Moderator
Astroman's Avatar
Please try to post your threads in the correct thread section. It's getting old moving all the stuff from the "general discussion" when this was service related. I've moved it to the proper sections
Old 10-08-2012, 11:16 PM   #38
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I haven't gotten an email from yarisworld in a while. Yeah the CEL will still come on like once a month for a couple days at a time. I took it to Advanced and checked it with their device. It said it was the MAF sensor. I'm gonna try the MAF sensor cleaner. I'm also planning on using cleaning my carburetor and fuel injectors soon for good measure.
33.7 mpg in PA
bad is offline   Reply With Quote
Old 10-08-2012, 11:17 PM   #39
bad
Winterizing
bad's Avatar
Ok astroman, my bad.
33.7 mpg in PA
Old 10-08-2012, 11:23 PM   #40
bad
Winterizing
bad's Avatar
Just wanted to mention I am starting to try to not use cruise control when going up hills anymore to see if I get higher mpg. I installed cruise around the same time I installed the air filter.
33.7 mpg in PA
Old 10-09-2012, 06:06 AM   #41
swidd
Drives: Yaris HB
I installed mine, got a code. Took off the spacers and re-seated the MAF seal with more care. No code for 200 miles, then all the sudden going uphill in fifth gear, it CELd again.
The way I installed the PVC hose it was pushing the Z-connector on the intake and creating an opening in the rubber gasket. I took some JB weld and permanently glued it on with a total cemented seal. No codes for 100 miles, even when going uphill with cruise control. It finally made a slight difference in MPG too -- had no change on the first fill-up.
Old 10-17-2012, 09:32 PM   #42
bad
Winterizing
bad's Avatar
Bought carburetor cleaning fluid, cleaned my air intake butterfly per some youtube videos. It looked very clean before I started though so I think it was a waste of time. I could not figure out how to open the butterfly to clean behind it so I had my dad spray a little in there while I got in and gave it gas. CEL light is still on. If it goes out and comes back on again I am going to have to buy MAF sensor cleaner and try that.
33.7 mpg in PA
Old 11-19-2012, 09:58 PM   #43
bad
Winterizing
bad's Avatar
Ok well the carburetor cleaner worked for like a day but then the CEL came back on and it stayed on for a long time. So I used some fuel injector cleaner and the CEL went off again. It only stayed off for about two days and then it went back on for a long time.
Finally I bought MAF cleaner. Sprayed the heck out of my MAF sensor, and it works well! The CEL light has been off for at least a week now. Once I quit using fuel perks and loading up gas tanks, I am going to calculate my new fuel economy. The MAF cleaning didn't work right away. It takes a little bit for the sensor to get used to being clean and also it might even make the CEL come back on for a tiny bit after it has gone off and then finally stay off.
SO in conclusion, I'm feeling confident that the MAF sensor cleaner was the way to go. All videos I watched say to not use carburetor cleaner on your MAF btw! I'd recommend cleaning the MAF sensor every once in a while now that I understand it can mean the difference in your car getting better gas milage too. (probably every other time you clean your filter would be fine.) So I'm happy right now. If you are having the CEL problem, buy MAF cleaner and follow a youtube video. It's as easy as spraying and letting dry. It only costed about $7 a can I think.
33.7 mpg in PA
Old 12-16-2012, 08:25 PM   #44
bad
Winterizing
bad's Avatar
Almost a month later and still no CEL. Engine doesn't seem to be so loud anymore too. Cleaning the MAF with MAF cleaner seems like it did the trick. Will figure out if the mpg got better soon.
33.7 mpg in PA
Old 01-09-2013, 09:16 PM   #45
bad
Winterizing
bad's Avatar
Still no CEL so that is good. ... I have not been getting very good mpg lately. I will try cleaning the air filter even though I don't think it is that dirty.
33.7 mpg in PA
Old 04-21-2013, 03:31 PM   #46
bad
Winterizing
bad's Avatar
Hi,
The CEL came back on about a month and a half ago and has stayed on. It went off for maybe a two day period about three weeks ago. But you could say I'm back to where I started. I'm feeling like I'm not sure if it was not worth it to install this AFE air filter and intake system. Especially since I haven't even seen any overwhelming gains in fuel efficiency.
I checked the codes last week and had two. One was MAF again and the other was air temperature sensor. I decided to try cleaning the MAF sensor since I already have a can of MAF cleaner. Since it turn the light off, I thought I would try replacing the air temp sensor today as it was less expensive than the MAF.
I went to my store and used the machine to read the codes and it only gave two this time for the MAF and none for the air temp sensor. I had them order me an MAF and will try it out on Thursday. I have to pay $50 and then get it back when I return the bad one.
I just cleaned the contacts of the MAF connectors with electrical contact cleaner and am waiting for them to dry now. Hoping that works so I don't have to buy the MAF sensor.
Just out of curiosity, could someone please post a link to show where the air temp sensor even is as I spent some time looking but don't think I found it. I saw a picture of it on my store's computer so I know it isn't part of the MAF sensor.
Any advice is appreciated also.
Thanks,
Mike
33.7 mpg in PA
Old 04-21-2013, 03:34 PM   #47
auxmike
auxmike's Avatar
I thought the air temp was but into the MAF.
Old 04-21-2013, 03:46 PM   #48
bad
Winterizing
bad's Avatar
I've read that on some websites, but they were able to pull up a separate part on their computer at Advanced Auto parts. The first time I had them pull up the part a week ago it was supposed to be like $11.99. The one they showed me on the computer today would be like $17.99.
You're probably right though...
33.7 mpg in PA
Old 04-21-2013, 03:50 PM   #49
auxmike
auxmike's Avatar
Can you snap a pic of what that part looks like? I'm curious...
Old 04-21-2013, 03:56 PM   #50
bad
Winterizing
bad's Avatar
I will try to get them to bring it up on the computer again when I go back and take a picture.
33.7 mpg in PA
Old 04-21-2013, 03:57 PM   #51
auxmike
auxmike's Avatar
Cool! Mabye it's a water temp part, dunno..
Old 04-21-2013, 03:57 PM   #52
bad
Winterizing
bad's Avatar
Question
I'm considering this also... where is the Z-connector?
33.7 mpg in PA
Old 04-21-2013, 04:36 PM   #53
bad
Winterizing
bad's Avatar
Is the Z connecter the small black hard plastic tube that is an elbow?
33.7 mpg in PA
Old 04-21-2013, 04:40 PM   #54
bad
Winterizing
bad's Avatar
I don't think so, as it was called air temp sensor.
33.7 mpg in PA
afe power cold air intake, air filter, air intake, check engine light, mpg
Check Engine and Traction Control Light On limey163 DIY / Maintenance / Service 21 07-14-2013 03:03 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
AFE cai intake....pros/cons severous01 Performance Modifications 21 06-30-2009 02:55 AM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
