Old 01-21-2015, 03:58 PM   #37
coolcolger
Drives: Streak Blue 2015 Yaris SE
Originally Posted by SineWave View Post
Forgot photos.
I know this is an old thread but I have the correct OEM camera for the rear hatch... The black "block off plate" insert thing that has the two bolts holding it in place that is clearly shown in SineWave's picture: how the heck do I get that off? The nuts that are attached to the bolts when turned cause the bolts themselves to turn as well. What am I missing here?
coolcolger is offline   Reply With Quote
Old 01-21-2015, 09:59 PM   #38
From his photos it looks like you can either insert an allen wrench into the end of the bolt, or hold it with a tiny socket to then let you loosen the nut.
Old 07-15-2015, 06:04 AM   #39
OGHUGO
Drives: 2015 Yaris 5 Door Hatchback
Had the same issue here they unscrew from the plastic piece of the cover. I had to remove the plastic piece very carefully and got it off but it was a pain in the butt. Also once you are about to put it back on you have to add the screws to the plastic piece and then add it to the back door. I have not done that as I want to add some jb wells glue or something to the screws so this will not happen again when/if I ever unscrew them.
cheap car, cheap parts, cheap it is cheap it does (stupid is, stupid does)
Let me know if you guys have had any issues removing this thing.
Also have found this camera that may just bold on to this car..
http://www.ebay.com/itm/171593317287...%3AMEBIDX%3AIT
been in touch with the seller and have provided pics and measurements of the black part that is on the car and he says this may fit. I have ordered it and should get it next week. I will let you guys know if it fits..
On that same note is there a harness that I can add an aftermarket cam to the stock head unit? I have the AXCP-Q15U (T10028) unit. Let me know, thanks.
OGHUGO is offline   Reply With Quote
Old 07-15-2015, 09:42 AM   #40
OGHUGO
There is no hole in the end of the screw, yes perhaps a tiny socket or even a pair of grip pliers will do but I only had a long socket with a rachet, so the screw was covered completely.
Anyhow I managed to take it off and just need some glue to add on the screws when I put it back in place so that the bolts do not spin as I tighten up the nut.
Old 07-15-2015, 09:58 AM   #41
OGHUGO
Also, tried to post a link for an after market camera but seems that my post have been deleted?? Don't know if im not supposed to link to ebay sellers but I see other people have done it so.
Anyhow I found a camera that may be a direct fit for this and I have been in contact with the seller I have sent him pics and measurements of the cover and he said that the one I ordered should fit. I should receive it next week I will let you guys know if it fit.
On that same note, is there a harness that I can use for a stock radio for the 2015 Yaris LE?
Thanks.
Old 07-22-2015, 09:40 AM   #42
OGHUGO
Update on the camera I purchased.. OK so I got the camera and no it does not fit properly it is not even long enough to reach the outside where the opening is on the plastic molding. So I tried to get another one that has a longer neck. Here is the ebay auction if you guys are interested.
http://www.ebay.com/itm/171593321191...%3AMEBIDX%3AIT
I will see if that works. and let you guys know.
What is the part number for the stock rear view camera and how much will it cost from the dealership any one know?
Old 07-22-2015, 11:51 AM   #43
OGHUGO
OK, while I wait for the new camera to arrive I wanted to start wiring my in the stuff I will need. Does anyone know where the wire for the reverse light is? Need to tap in to that for the head unit to properly display the camera when in revers.
Thanks in advance.
Old 07-22-2015, 10:26 PM   #44
ucsmfu
Drives: yaris le
Thanks in advance.
this was the one I got and it was a perfect fit
http://www.aliexpress.com/item/SONY-...536788227.html
This is the harness I bought and it worked well as well.
http://www.autoharnesshouse.com/19867.html
Very easy to install
http://www.autoharnesshouse.com/1/pr...amera_conn.jpg
Everything is plug and play except the reverse trigger wire where you have to plug in to the 28 pin connector on the back of your head unit and splice it to the reverse wire either on your ECU or reverse lights.
http://www.autoharnesshouse.com/19867_add.html
Let me know if you have anymore questions.
ucsmfu is offline   Reply With Quote
Old 07-23-2015, 03:51 AM   #45
OGHUGO
Man thanks for the info, however how is it that the camera you got was a perfect fit? did you leave the hole in the car after the install? that looks like it will just fit on the molding but doesn't seem like it will cover up the home that is left on the actual door. I want something that is going to go bolted on the 2 bolts and goes straight outside sortha like the actual factory one with out having to pay factory prices.
Also where is the wire for the ecu that I need to tap into?
Thanks again.
Old 07-23-2015, 05:36 AM   #46
ucsmfu
Drives: yaris le
Thanks again.
I'll take pics for you tomorrow, it is a perfect fit, eventhough it doesn't mount on the two screws, it's a perfect fit and won't fall out.
I didn't tap to ecu because I didn't wanna mess around with it, tapped the reverse trigger wire to the reverse light red wire :)
Old 07-26-2015, 08:30 PM   #47
OGHUGO
Ok, so i got the other camera and no go still does not fit. now its like $65 for the cost of both cameras and no go. I talked to the seller and he said he can refund if I return them but have to pay for shipping to china.. I have given up on trying to find one that is like the oem and got one like the one you got UCSMFU but got it from a us seller for $23 rather wait a few days than a couple of weeks.
Now I have everything ran all cables but need to get the right cable for the reverse trigger. Does someone have pics of where this is located?
Thanks.
Old 07-26-2015, 09:13 PM   #48
ucsmfu
Drives: yaris le
Thanks.
yes Eduardo did, wired it up to the ECU
http://www.yarisworld.com/forums/showthread.php?t=52850
Old 07-28-2015, 05:21 AM   #49
OGHUGO
Is that below the steering wheel column? I did not see that on the side.
Also tried to remove the covers and they hard as shit to remove.
Old 07-28-2015, 10:34 PM   #50
ucsmfu
Drives: yaris le
yes on the left side bottom, above the foot rest.
Old 06-11-2017, 11:16 AM   #51
yeasin
Drives: 2015 yaris
The Toyota part number for the camera is: 86790-0D010
That part number is unique to the Yaris, but the shape of the camera looks identical to the one on my Tacoma.
For the Yaris, the camera connector should be a 6 pin connector, with 4 wires: Brown is power ground, red is +12 power, black is video and white is video ground.
red is 6+ not 12+
yeasin is offline   Reply With Quote
Old 12-27-2017, 09:12 PM   #52
chaditotx
Drives: 2007 3dr hb 5sp
I have a 2012 Se with retrofitted touch screen and nav. I bought the camera 86790-0D010 used from a parts house in Ireland. It just arrived, but I am trying to find the pigtail that goes from the camera to the hatch wiring. My wiring looks exactly as above. I can't seem to find the pigtail anywhere, or the wiring diagram for the hookup. Yes, I realize this is an old thread LOL
chaditotx is offline   Reply With Quote
Old 12-28-2017, 09:56 AM   #53
logoris
Drives: 2017 Yaris SE Blue Streak
That is exactly what I needed, iv been looking for an adapter.
should this work on the 2017 se?
I have a camera already similar to the beatsonic style just to get it plugged in,
will standard cameras work? or will the view be off as it off to the side?
logoris is offline   Reply With Quote
Old 12-28-2017, 03:28 PM   #54
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Here's the camera I fitted. It was listed on eBay as fitting a Camry. It plugged into the hole from outside. It needed sealant around it as it is smaller that the opening (same width but can slide forward and back).
Also a pic of the view from the camera of my other car behind the Yaris in the driveway.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
