Old 05-09-2013, 05:37 PM   #1
Jerkratt
Jerkratt's Avatar
You got a lap top i got my fic lol you can looms at my setup.. But I'm sc
"It hurts more when its wet"
Old 09-27-2014, 03:33 PM   #2
kou
Drives: 08 lb
Its been a while since I have been on. The Yaris is still alive and well but I am getting bored and need more power. So I had to do some shopping. Built bottom end CP pistons and Molnar rods, rebuilt a stock head, got a -10 fitting welded to my upper pan for an oil return I bought a full engine gasket kit new chain guides a chain and tensioner new head bolts and a bunch of other misc bolts and parts. I have also ordered a TRD LSD a new clutch. Hope to have it all put together over the next month.
Old 09-27-2014, 03:54 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
forgot....did you uprgade your TB yet?
Old 09-27-2014, 03:57 PM   #4
kou
Drives: 08 lb
Yes I am running the corolla TB with a ported factory manifold.
Old 09-27-2014, 05:15 PM   #5
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
pics?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 09-27-2014, 06:34 PM   #6
kou
Drives: 08 lb
http://www.yarisworld.com/forums/sho...+body+swap+cel
Old 09-28-2014, 12:40 PM   #7
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
How much boost are you planning to run? Can't wait to see this project finished. :)
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 09-28-2014, 08:05 PM   #8
kou
Drives: 08 lb
Not sure on the boost number but I would like to have somewhere around. 250whp.
Old 09-28-2014, 11:13 PM   #9
That will take approximately 15-16 psi. Are you doing head work?
Old 09-29-2014, 12:35 PM   #10
kou
Drives: 08 lb
No head work at this time just had a factory head rebuilt with new valve seals and one new valve.
Old 10-17-2014, 05:17 PM   #11
kou
Drives: 08 lb
Nearly time for motor swap and LSD install.
Old 11-29-2014, 03:37 PM   #12
kou
Drives: 08 lb
Just installed my new built motor,TRD lsd and new clutch. Will post some pictures later. Still have a couple of hundred miles for the clutch breakin.
Old 11-29-2014, 05:40 PM   #13
LTHatch
Drives: 2013 Yaris Hatchback L
Can't wait to see the new motor in the car, nicely done!
LTHatch is offline   Reply With Quote
Old 12-02-2014, 12:58 PM   #14
kou
Drives: 08 lb
Some of these shots are crappy don't know what happened. whole job took about 8hrs that included lsd install which I did the way some people would say is wrong but it seems to be fine.
Old 12-02-2014, 02:46 PM   #15
BoostedTRD
Drives: 09 Yaris Hatchback
awesome, when will you get it tuned? and if you did please post the numbers
BoostedTRD is offline   Reply With Quote
Old 12-02-2014, 04:25 PM   #16
kou
Drives: 08 lb
Thanks. I am still running the same tune at the moment while breaking in the clutch and engine. I have been looking for somewhere to dyno tune but may just end up doing another street tune and some drag strip tuning as not many people work with the AEM FIC or just dont want to even though its pretty easy.
Old 12-02-2014, 07:44 PM   #17
What's all that black stuff on the block in the picture?
Old 12-03-2014, 02:17 PM   #18
kou
Drives: 08 lb
Maybe a mix of oil,road grime,belt not really sure front cover may have been leaking a little. That is my 135k original motor.
Dashboard lights turn off when I turn use headlights patate15 DIY / Maintenance / Service 7 07-05-2020 03:05 AM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
