Old 08-26-2012, 08:35 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
too bad you can't take full advantage of the compression with bigger cams
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 08-21-2012, 12:02 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Or enjoying all of that powaaaa lol ^
Old 08-22-2012, 12:53 AM   #3
Nanoss22
Drives: Yaris sedan 10 std...
Sorry i was specting to have the numbers to and for the moment i dont have the time to go and do the dynopull the work family and the college got me crazy and yes the engine is running good no problems for the moment the car feel very diferent when i step on it so dont worry i will gave u the numbers and some videos of the dynopull... So be pacient
Nanoss22 is offline   Reply With Quote
Old 09-16-2012, 06:13 PM   #4
taman86
Drives: scion xa
So any update to this? Still running? Dyno? Also I was wondering what engine managment you are using to run these. Stock, piggyback, or standalone? Where did you souce these from, new or another engine.
taman86 is offline   Reply With Quote
Old 09-16-2012, 08:53 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
we are all still waiting for some kinda update on this one..
-Derrick-
Old 09-18-2012, 02:36 PM   #6
taman86
Drives: scion xa
does anyone have this guys number and give him a call. I WANT UPDATES!!!
Old 09-20-2012, 05:35 AM   #7
moh
moh's Avatar
Drives: Yaris Sedan
+1
|Blitz S/C|aFe Intake|NST SSK|NST Busing kit|Ralco Short Shifter|Dastek Unichip type Q|Dastek Throttle Control|1ZZ Injectors|1ZZ TB|Custom Header|Custom Exhaust|Head Porting|Momo Drifting Steering wheel|Momo shiftknob|Denso Irridium Sparks|Buddy Club P1 Racing Wheels|195/50/R15|Tanabe NF Coilover|Goodrich SS brake lines|Ultra Racing Front Strutbar|NRG Grounding kit|Custom Grill|Custom Eyelid|Rear Sway bar|
moh is offline   Reply With Quote
Old 09-29-2012, 11:54 PM   #8
Autocross72
Drives: 2009 3rd Polar white
I'm guessing he blew up the engine. That is way too much compression to be running on pump gas and cast pistons. To run as much compression as he had you would need forged pistons and run race gas. Mother wise you would not be able to control detonation. Of course, he could prove me wrong by posting an up date, but physics predicts that he won't be doing that.
Autocross72 is offline   Reply With Quote
Old 11-05-2012, 10:47 PM   #9
Viperoni
Drives: 2005 Toyota Echo
You sure that the motor would gain that much power from a 1.5 point compression ratio bump that the cast pistons and stock rods would crack and pop?
Worst case you need 94 octane.
2006 Saturn Ion Redline
Old 11-02-2012, 11:50 AM   #10
jetblast
Drives: Gen 1 XB
Don't forget the toothpick con rods.
jetblast is offline   Reply With Quote
Old 11-06-2012, 04:40 AM   #11
ilikerice
ilikerice's Avatar
@Viperoni
I dont think its the "power" that he is referring to that will blow up the motor, but the compression itself and not using correct precautions. We will never know because OP hasnt updated
-Derrick-
Old 04-06-2013, 09:06 AM   #12
fast2882
Drives: Toyota Yaris 2012
Hello there, any update ? dyno result maybe?
fast2882 is offline   Reply With Quote
Old 04-06-2013, 10:26 AM   #13
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
what would go first the cylinder walls or the connecting rods?
Old 04-06-2013, 01:01 PM   #14
fast2882
maybe piston hit the valve
Old 04-08-2013, 01:18 PM   #15
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Doubt either...
Possible.. Would def want to clay before starting the car.
A lot of this is repeat from other threads..but seems very feasible:
Originally Posted by Viperoni
The (static) CR would be 13:1 if you use Prius (FXE) pistons.
The dynamic CR is apparently 11:1 if you use FXE pistons
The most I may need to change when running 11:1 compression is 91 instead of 87 pump gas, besides some EM. But even then....I run on 87 now...at the supposed static CR of 13:1 or dynamic 11:1.
List of Different Parts:
Crankshaft:
1NZ-FE: 13401-21020
1NZ-FXE: 13401-21040
Cam 1:
1NZ-FE:13502-21031
1NZ-FXE: 13502-21021
Cam 2:
1NZ-FE:13501-21030
1NZ-FXE: 13501-21060
Cam Gear:
1NZ-FE: 13050-21041
1NZ-FXE: 13050-21051)
Rings:
1NZ-FE: 13011-21041
1NZ-FXE: 13011-21100
Pistons:
1NZ-FE: 13101-21070
1NZ-FXE: 13101-21110
Valve Springs:
1NZ-FE: 90905-01049
1NZ-FXE: 90501-23135
List of parts that ARE the same...
Sprocket:
1NZ-FE: 13050-21041
1NZ-FXE: 13050-21041
Timing Chain:
1NZ-FE: 13506-21050
1NZ-FXE: 13506-21050
Rods:
1NZ-FE: 13201-29735
1NZ-FXE: 13201-29735
Bearings: all three SAME
13041-21022-01
13041-21022-02
13041-21022-03
Cylinder Head:
1NZ-FE: 11101-21062
1NZ-FXE: 11101-21062
Engine Block:
1NZ-FE: 11401-29856
1NZ-FXE: 11401-29856
Valves Seals:
1NZ-FE: 90913-02092
1NZ-FXE: 90913-02092
Intake Valves:
1NZ-FE: 13711-21010
1NZ-FXE: 13711-21010
Exhaust Valves:
1NZ-FE: 13715-21010
1NZ-FXE: 13715-21010
JustDidIt is offline   Reply With Quote
Old 04-06-2013, 10:10 PM   #16
Golddeenoh
Golddeenoh's Avatar
i was referring to should it function what would stress out first. valve clearance would be the first issue maybe a shim gasket to gain clearance and lower compression ratio while also adding block guards might work great.
Old 04-07-2013, 10:53 AM   #17
fast2882
too bad the project isn't work, i still really curious about the result if someone can swap this piston and have about 12:1 compression ratio in 1nz-fe engine. toyota 1NR-fe engine series have 11.5:1 compression ratio, so i think actually it is possible to have 12:1 too.
Old 04-07-2013, 11:27 AM   #18
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I think 12:1 is possible and even 12.5:1 with premium gas. the prius pistons are 13:1 so it is pushing it.
MicroImage has higher compression pistons for sale but i don't know of anyone that has done it. his 9:1 pistons are very popular in the boosted community.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 12:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
