#37 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
Drove most of last week in the rain to and from work. The rear is useless though!!
Cheapest DD I could find!! |
#38 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
#39 |
![]() ![]() Drives: Yaris Hatchback 2012 SE Join Date: Aug 2011
Agreed the front wiper is not a trouble, but the rear one is just worthless weight :)
#40 |
#41 | |
Asshole
#42 |
![]() Drives: 2012 5dr Manual Yaris Join Date: Jun 2012
I like the single wiper, but trying to find a cheap alternative to replacing the full wiper with just a slide in insert.
Also, going to put a longer rear wiper on as there is room for it. |
#43 |
Let me know how the bigger wiper on the back works to see if I do it and then stop saying that is worthless weight :D
#44 |
![]() ![]() Drives: '13 Super White SE Join Date: Apr 2012
Yes what size wiper will fit in the back? The current is only 12"!
#45 |
Absolute, was wondering if you could provide video/pic instructions as to how you got that chrome trim piece off?
#46 |
Asshole
Remove the inside hatch panel with a clip removal tool.
http://www.amazon.com/Automotive-Mol...moval+tool+set Remove screws and clips holding the trim piece on, from the insode!!
#47 |
Im sorry if this is a dumb question lol....do this with hatch open or closed?
#48 |
And with those tools (or a prybar) the hatch panel just pops off and back on when you're done?
#49 |
Asshole
Open the hatch, look up, remove the panel.
Looking up inside the cavity, find 4 to 6 bolts sticking through, along the imaginary line of the trim. Remove nuts from bolts. The trim is now held on by two clips on either end, using needle nose pliers, from the inside, squeeze clips, to release. As I stated earlier, you WILL NEED new sealing washers, between the trim, and hatch, on the through bolts. I bought very thin 1/4" rubber washers at Lowes.
#50 |
Asshole
The hatch cover removes, and installs just like a door panel.
Dont use a metal panel remover, use a nylon one, else you will scratch the paint.
#51 |
thanks buddy, i'll try it out!
#52 |
Dumb question, but is that trim piece actually metal that could maybe be powder coated? Or is it just plastic like the badges/emblems?
#53 |
no show, no go :(
it's plastic.
#54 |
Asshole
^ What he said.
Chrome plastic, not plated. Just scuff it, spray adhesion promoter, 2 coats of primer, 3 coats of base, 3 coats of clear. If youre car is red, I recommend pink primer.
| 2012 trim piece question | Shroomster | Third Gen Yaris General Discussion | 12 | 09-05-2012 12:08 PM |
| 2nd-Gen Yaris hatch at San Diego Comic Con 2012 | Mitey | Photo-Video-Media Gallery | 4 | 07-17-2012 09:21 PM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| First Drive: 2012 Ford Focus | Kal-El | Off-topic / Other Cars / Everything else Discussions | 18 | 02-25-2011 05:41 PM |
| Yaris sedan - how to remove chrome trim on trunk? | Herbicidal | Cosmetic Modifications (Exterior/Interior) | 29 | 11-01-2009 11:05 PM |
