Old 10-25-2012, 09:54 PM   #1
P205
Drives: 2008 yaris 1.4
what NEexpat seems to make sences
P205 is offline   Reply With Quote
Old 10-26-2012, 02:09 AM   #2
Yeah, when the engine is cold, the ECU runs pig rich. On my Scan Gauge, it'll read on average in the teens and low 20's, but then again I have a heavy rim/tire combo. But with that being said, even if I'm smashing on the gas all day everyday, I'll still be in the low 30's mpg.
And with that being said, I'll say check your tire pressure and make sure it's 32 psi at the lowest (I drive around at 51 psi), and check your alignment. Those two can really kill your mpg's.
Old 10-26-2012, 02:44 AM   #3
P205
I have my psi at about 46 and the car drives straight as an arrow,
Old 10-26-2012, 09:30 PM   #4
Kar98
Drives: 2011 Scion tC
Originally Posted by P205 View Post
I have my psi at about 46...
That's a lot. I'd stick with 32.
Old 10-26-2012, 03:12 AM   #5
hmmmm, I would have your brakes checked. They might be producing too much friction, causing your engine to work harder to get the car to speed and to maintain speed. If your tire pressure is high and your alignment is within manufacturer specs, you really shouldn't be having mpg issues.
So have your brakes checked, change your spark plugs, and change your intake air filter. Also, if you are using cheapo gas, I'd suggest switching to a top tier station.
Old 10-26-2012, 04:38 PM   #6
P205
I have gotten new spark plugs, what you you guys prefer ?
Old 10-26-2012, 11:10 PM   #7
charles nelson
Drives: red Liftback
Popular Mechanics had an article about tire pressure and mpg. The manufacturers recommended pressure is designed to put the least wear on the suspension. Significantly higher tire pressure will increase your mileage (less road friction) but will greatly increase suspension wear. So with higher pressure you get better mileage and lower fuel costs but higher repair bills later on.
charles nelson is offline   Reply With Quote
Old 10-27-2012, 12:07 AM   #8
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
it is possible... translate into km that is 350km. On my yaris, i fit it with mini cooper 17" wheels(heavy) and now i've lost 30km on a full tank.
I drive 50/50 city and highway, and I am only getting 430km, then the fuel light flashes, about 9.4L/100km.
so basically if I were doing 90-100% city, it is not surprising to get 350km(218 miles)
if you do the math, or just google look it up my numbers translate back to your mpg or miles, you will get an idea.
my car is completely stock under the hood.
caineroad is offline   Reply With Quote
Old 10-27-2012, 01:19 AM   #9
P205
well i find it odd because looking at the mpg people are getting in the forums, a lot of them are getting Lazy 30mpg all city driving
Old 10-27-2012, 10:51 AM   #10
Kar98
Yeah, city driving, I'm driving 17 miles to work in one rather large city. Not three miles, and letting it idle for two minutes. I'm surprised you're even getting 21 mpg.
Old 10-27-2012, 11:49 AM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
You just implied another variable that no one seems to ever mention:
Wheel Diameter
Almost everyone here runs different diameter rims combined with a wide variety of different sized tires...
...and yet no one seems to be factoring in their wheel diameters to adjust their odometer readings to arrive at their actual gas mileage.
I changed my rims and tires just like everyone else, except I used a wheel diameter chart to determine the tire size and aspect ratio so as to keep the diameter within 1% of the stock diameter so that my odometer continues to give accurate readings.
Old 10-27-2012, 11:56 AM   #12
P205
I wonder if by city driving people are in the city on the highway long trips at high speeds, when i say 100% city driving i mean stop lights often
Old 10-27-2012, 12:19 PM   #13
tooter
play every day
tooter's Avatar
I know what you mean. I often drive in traffic for long periods of time. My last fillup was only 36mpg. The computer showed the overall average speed for that fillup was only 7 mph!
Old 10-27-2012, 01:30 PM   #14
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Something aint right try some of the obvious fixes then i'd say it would be worth your while to take it to a reputable garage and get it fixed..
http://www.carsdirect.com/car-buying...ad-gas-mileage
Have Yaris will travel..
Old 12-14-2012, 02:25 AM   #15
caineroad
caineroad's Avatar
Wheel Diameter
Good job you brought this up... i didn't realize that.
Ever since I changed to 17' Cooper S rims, my speedo is slower than actual speed. Therefore the distance counter must be also slower (less), that would make sense to the loss mileage!
Old 10-27-2012, 03:41 PM   #16
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
OP did you change your oil lately?
OTA'sTOY is offline   Reply With Quote
Old 10-27-2012, 04:52 PM   #17
P205
yes i did, 5w 30 royal purple
Old 12-11-2012, 11:00 PM   #18
Martinezn.964
Drives: 07 Sedan S
Original Intake gets you better gas milage. Try it
Martinezn.964 is offline   Reply With Quote
gas, mpg
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Why sub-compacts and compacts get almost the same MPG Kal-El Off-topic / Other Cars / Everything else Discussions 0 08-10-2011 11:51 PM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
