#37 | |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
um???? I think I have a blue???? light when the engine is cold, but it goes out almost instantly in the summer, and only stays on briefly in the fall and spring. I actually know the exact water temps because I've been driving around staring at my Scan Guage. ............................??? |
#38 | |
What are you seeing for temps? Normally the Yaris will sit in the low to mid 180's F when cruising.
#39 |
![]() Dunno, ..............It was crazy. None of the 5 ARP studs would fit into the two outer holes, they refused to thread into the holes. At first I thought it was maybe just one bad ARP stud / or one of the outer holes was cross threaded????? ![]() NOPE -None of the 5 ARP studs would thread into either of the outer holes, but they all would easily thread into the 3 inner holes -All of the OEM hardware (studs or bolts) easily threads into the outer holes (as well as the 3 inner holes) So.........................right now I have 3 ARP head studs in the inner locations (where the bolts were) .............and the factory OEM studs in the outer locations (but with the ARP nuts) and then of course, 2 unused very expensive ARP studs in a bag in my tool box.
#40 | |
I'll take my toy (The Yaris) for a drive tonight and pay attention to both the color of the light (when the car starts) and the water temp (in deg F) Will |
#41 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
For my car on the freeway, my coolant runs between 179-184*. City driving goes from 180-190's. Parking lot goes up to 202, or around there where the fan kicks in. lol
#42 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
It's blue on my Canadian Echo, takes a minute or two to turn off in the summer time. Never saw it turn red, even at lower speed road courses.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#43 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Hey Will,
Has anything changed with the stock temprature thermostat? Greg |
#44 | |
Just picked up extra coolant on Friday night (some is always lost when changing a T Stat) and then was busy with other crap all weekend. I'm booked the next few nights after work, so the first free opportunity is probably Friday night (to swap back to stock T Stat and then after that maybe also try the stock TB) W |
#45 | |
I drove it briefly yesterday and I was seeing temps in the 140 - 175 range when cruising (outside temperature was approx 91) |
#46 | |
play every day
Be sure to let me know what happens, because if you're not satisfied, you get your money back. ![]() Greg |
#47 | |
Once the engine gets past the cold start range, the coolant temperature is still used for camshaft timing control: "Camshaft timing control is performed according to engine operating conditions such as the intake air volume, throttle valve position and engine coolant temperature." So, I still think that Jason's take on the performance thermostat being the culprit has merit.
#48 |
At 175, I can't imagine it's in cold start mode. Is the OP losing power at that full temp reading?
#49 |
175 is over the cold start mode, but he said cruising that he was seeing 140 to 175. If in motion it stays down to the 140 mode, it will run more like the cold mode.
#50 |
If I have the time tonight I'll take it out for a drive and try to get some #'s
At this point its looking like the soonest I can swap the T-Stat is Friday night or Saturday afternoon. ![]() Will |
#51 |
It's ok. We'll wait. We gave Astroman over eight months. You're good.
#52 | |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#53 |
#54 |
| DC Sports Header install and evaluation | Loren | Performance Modifications | 217 | 07-04-2017 06:40 AM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| Megan Racing header install and review with pics. | Herbicidal | Performance Modifications | 6 | 09-03-2009 08:40 AM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
