#37 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
that is what i have been running my last 2 oil changes
#38 |
der Zeck
many efficient cars run low viscosity oil because they can with out causing any damage to the engine, but if you notice, the only way you can get those realy low viscosities is full synthetic
#39 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
okay, couple more questions. for daily driving/carpooling, 0W-20 is fine? and two, where can i get Amsoil?
heh, i actually have a third question, so for tomorrow, should i stick to conventional motor oil until i find some Amsoil, or should i go with Royal Purple or Redline? |
#40 |
Drives: LB Join Date: Jul 2006
[1] In California, 0W-20 is perfectly fine. You don't deal with the weather we get here.
[2] Amsoil is a special-order type deal. I have never seen Amsoil in a store around here. [3] Honestly, I'd go with whatever is readily available and reasonably priced, because when you get down to it there isn't two specks of difference between any of them. Go high quality and you're in there... Redline, Amsoil, Royal Purple, Mobil 1 full syn... all are awesome. |
#41 |
der Zeck
just go to something synthetic.... I went back to mobile cause Amsoil was too hard to get ahold of.... I drive everyday, alot and I am running 0w-20, yes you can run it, Toyota would not have put out a TSB if it would fuck your car up, that would be a law suit waiting to happen if they did
#42 | |
2. dang... 3. i think i'll go with Royal Purple since it's the cheapest full synthetic (i think). |
#43 | |
oh, and does RP have 0W-20? |
#44 |
der Zeck
We are in Ohio... so far in the last week we have had sunshine in the 70's and yesterday and today it snowed....
#45 | |
der Zeck
It is a Toyota TSB, TSB= Techical Service Buliten... basicly a message they put out to shops
#46 |
owner's manual says on pg. 259 and 283, 5W-30 is the recommended...
#47 |
#48 |
#49 |
der Zeck
It's your car you can do what you want... if you do not believe us just go to your local Toyota dealer and ask them to pull up ant TSB's on the 1NZ engine and POOF it will say everything Chino and I have been trying to tell you for the last hour or so
#50 |
der Zeck
Yeah... That is Ohio for ya... Sunbathing and Snowskiing all in the same week
#51 | |
ok, i just have to find out if RP makes a 0W-20 weight. |
#52 |
#53 |
der Zeck
the TSB suggest 0w-20 or 5w-20, 5w-20 is more common
#54 |
![]() ![]() ![]() Drives: Yaris S Sedan color Flint Mica Join Date: Jan 2007
it dont say 0w-20 is ok but put 5w30 back in asap?
thats what mine says. |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Synthetic oil MPG boost since change | Yaris Dick | General Yaris / Vitz Discussion | 29 | 09-15-2007 08:15 PM |
| Oil Question | 91drggndime | DIY / Maintenance / Service | 7 | 03-23-2007 06:52 PM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 08:44 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
