Old 05-08-2007, 04:14 AM   #37
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
+42
ty
barebonedvitz is offline   Reply With Quote
Old 05-08-2007, 07:50 AM   #38
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
the most beautiful, wondrous and amazing wheel and tire size calculator ever:
http://www.rims-n-tires.com/rt_specs.jsp
That is pretty cool! I like the real-time cross-section of the wheels & tires.
2006 Red Blitzed RS 5-door
Old 05-10-2007, 06:33 AM   #39
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Hey peeps i gotta a question.....well i baught my wheels, they are still at the painters.
Though im stuck on what the hell what profile tyres to get. Whatever u wanna call it.
I know it says 205/40/17...............i get the 40/17 part
but question is with the 195/205/215/225 and so on......is this the tyre width??? or how "skinny" the tyres are from rim to whatever. Sorry i cant make the question clearer....so i photoshopped some tyres....weeeeee
1 or 2?
Old 05-10-2007, 06:54 AM   #40
the first number is #2 in your picture. Then the second number (40), which corresponds to number 1 in your picture, is the percentage of the tire width... confused yet?
Go look at that site I just posted, play around with it, it will clear up a lot of things
Old 05-10-2007, 07:06 AM   #41
hasher22
Look mum no stars!!
hasher22's Avatar
Thanks....that was cleared some things up like u said
Ok well this is what i want;
The wheels i baught are 17/7.5/40
Would this be a good tyre fitment..?? 205/30/17 since i want the "number 1" (in the picture i posted) to be thin to make the wheels look bigger.
Old 05-10-2007, 08:50 AM   #42
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Hey Hasher... ok... when talking about wheel sizes, you usually only refer to their diameter (17 inches) and their width (seems like 7.5" in your case). Not sure where you're getting the "40" number from for the wheel. So I'm guessing your wheel is 17 x 7.5, yes?
So for tires, the main goal is to try to maintain the same overal diameter as your original tires. So if you go with a bigger wheel, you need a smaller sidewall so overall, everything stays the same. While putting on a 30 series tire (who's sidewall is 30% the width of the tire) may look good to you, it will be too small a tire for the car, and your speedmeter will be off. If you must-must-must have a 30 series tire, you'll need a wider tire... like a 225 or something. For a 205mm wide tire, a 40 series profile is perfect.
Good luck!
Old 06-24-2007, 02:21 AM   #43
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
+35 offset work ok with some 215/50/16's lowered with Tanabe DF's?
Old 06-24-2007, 10:47 AM   #44
Black Yaris
der Zeck
Black Yaris's Avatar
if you want them to rub your fenders on bumps, tire is too wide to run with that offset with DF's
Old 06-24-2007, 08:55 PM   #45
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
Theoretically speaking* my 215/45R17's are 3.8% larger than the OE fitment, but 4+ months and 6000+ KM down the track I've no problems at all to report.
Even when fully loaded for a 2500KM journey last April (giving it a ~2" drop) I only experienced two light rubs in the front - but that was only when hitting some pretty nasty bumps at 140+ KM/hr :)
Speedo seems bang-on to me as well, so I'm guessing the stock calibration is on the low side to begin with. Ride quality is 95% as good as the OE tires, but handling and general stability is much improved of course. I will stick to this size when buying tires again fer sure!
* I say Theoretically because it all depends on your weght load vs. infaltion pressure of course. It's pretty easy to add a couple of % to your rolling circumference by increasing the tire pressure.
Razr is offline   Reply With Quote
Old 06-24-2007, 09:10 PM   #46
Black Yaris
der Zeck
but that was in the rear only, the problem lies in the front
Old 06-25-2007, 07:08 AM   #47
Razr
YRS WHOR
Razr's Avatar
Not so - the front passenger seat was fully loaded, as was the drivers seat :P
The drop was pretty much the same front & rear. On top of that, both front rubs happened under heavy (albeit late - it was night) braking, so even more weight would have been distributed to the front.
Old 06-25-2007, 03:41 PM   #48
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Exclamation
BUMP for N00bz
SPONSORED BY
Old 06-26-2007, 04:11 AM   #49
Edd
Drives: None
Some of you don't seem to be quite clear with what the measurements are. It usually goes tyre width/aspect/rim diameter, in mm/%/inches, eg 185/65/16. Here's a diagram.
Edd is offline   Reply With Quote
Old 06-26-2007, 04:39 PM   #50
kurokoma-kun
Drives: 2007 Yaris HB
OK. please, please don't flame me for this question. I have searched and read and I do understand what the x/x/x numbers mean, but...
Why is 195/60/15 not recommended size?
My reason for asking is I just bought 15x6.5 wheels, and have been trying to find 195/55s, but no local shop has them in stock! Another option is Discount Tire Direct because I have a $50 coupon, but the 55s are MUCH more expensive than the 60s!
I'm guessing the 60s will be ok, even tho speedo will be off a bit, just wanted to run it by the experts...
my yaris, kurokoma-kun
Old 06-26-2007, 05:05 PM   #51
brickhardmeat
Lonesome Cowboy
60 is too much side wall babe
I went with 205/50/15
edgeracing.com may have exactly what you are looking for or you could go 205/55/15
SPONSORED BY
Old 06-26-2007, 07:47 PM   #52
kurokoma-kun
Yeah, you're right. I know you are supposed to maintain stock wheel/tire diameter so as not affect suspension geometry. But I was not understanding clearly how much increased sidewall height affects cornering. That extra flex supposedly gives better ride but makes for sloppy cornering, exact opposite of what i'm going for.
Was just trying to save money again--dayam, why am I so cheap? But it turns out there are LOTS of good 205/50 choices so that what I'm getting! Springs/shocks next!
Old 06-26-2007, 07:54 PM   #53
brickhardmeat
Lonesome Cowboy
205/50/15 is my #1 choice on this car. It will only slightly thow the speedo and the odo at 10000 will likely read 10300 not enough to make any difference for me. It just looks right to me. you will want a good drop though because you'll be dealing with an extra 1/2 inch of wheel gap so I would suggest DF's or Coilovers or Tein springs. Just something to consider. I got my Basics today and I am drooling over them right now.
SPONSORED BY
Last edited by brickhardmeat; 06-26-2007 at 07:55 PM. Reason: I figured you would say something like "Don't call me babe"
Old 06-27-2007, 03:32 AM   #54
Edd
Drives: None
Heh, you should go extremely the other way, so when you go to sell "Yaris, 7 miles, excellent condition, 5 years old".
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
