#1 |
25 Car With Mpg Good As Hybrids
Synthetic Oil: Its All In Your Head |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
Yep, but that's only for hwy numbers. Look at city mpg or combined mpg and the gap is huge. I commute in city only and when switched from corolla to prius, I instantly doubled mpg from 28 to 55. My kid who drives Yaris in city also gets 28 mpg. She is not a hypermiller for sure.
#3 |
True dat.
Now factor in the increased expense incurred in buying a hybrid over a car like a Yaris and run the numbers again. BTW I get 35 mpg in my Yaris driving 6.5 miles twice a day going to work.
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
#5 | |
This is true. That and increased initial cost and largely offsets any savings from increased mpg.
#6 |
#7 | |
It nice and hot in Houston and I bet thats why.
#8 |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
while a hybrid has the big advantage in the city, keep in mind that if true city driving is most of your commute, the number of miles is much less than for others.
I used to drive exclusively in Chicago traffic at 50 miles per week. while the hybrid mileage would be great, at 25 mpg's, I would only use about $8 per week for gas. at 50 mpg in a hybrid I would need 1 gallon, so $4. so, the hybrid city advantage sounds great, but is it? in my scenario I would save $4 per week, $208 per year. it would take 10 years to save roughly $2000. now, I have a mostly rural and light suburban commute, similar to my brother, who drives a prius. he averages 46 mpg, I average 42+. that saves him $128 per year if we both drive 15,000 miles per year. |
#9 |
![]() ![]() ![]() Drives: 09 Yaris 3dr HB, BRZ Join Date: Mar 2011
My commute is 50 miles each way at 60-80mph.. No point in my buying a hybrid, even if there wasn't a premium price attached to them. Now a diesel.. maybe but of course the only real diesel option yet is the VW's and no thanks! Even the premium price for the diesel and then the more costly service.. and then the fluctuating price of diesel.. make it hard to justify.
Now when I can buy a hybrid or even plug in, that can do 150-200 miles on a charge at highway speeds .. maybe then.. so long as the price doesn't out weigh the fuel savings. and wtf is with all the 80mph prius's ... treehugger by night.. lumberjack by day? |
#10 | |
You should either compare Prius to Matrix with AT or Prius C to Yaris AT. In my case, the hybrid premium over Matrix melted in 50,000 miles of city driving (yes, I drive a lot in city). |
#11 |
Yeah, the heat shortens the life of batteries, but the absence of the cold you guys get (as well as other northern parts of the U.S. and just about all of Canada) means we don't really get winter MPG dip solely attributable to temperature. The NAPA Legend battery (same one CTScott uses) that I got at 274,086 miles = a few cents of difference when compared to the previous 2 batteries combined.....$130.99 net (120.99 net + 10.00 installation at a local place) vs $131.52 ----- ($70.09 including install for a 1yr guarantee Sears that I milked to exactly 3 yrs and 86,891 miles (after getting 138,055 and just under 3yrs re the OEM battery).....then $61.43 including installation for a 1yr guarantee Wal-Mart battery that lasted 16 months and 49,860 miles).....but the NAPA Legend is light years better.....SO worth the extra cost.
#12 |
Hmm my wifes Camry battery lasted 6 years and my ECHOs battery seven....the Yaris still has it org one and its five years old.
#13 |
I took a trip to Ann Arbor and back yesterday.
cargo: Me (220 lbs), Dad (185 lbs), 2 dogs (90 lbs), misc (30 lbs) 182 miles each way going: U.S. highway-45-62 mph with a scattering of small towns to drive through. moderately hilly. return: I-94 most of the way. 65-75 mph for about 80% of the return. the rest rural. 364 miles driven. 8.12 gallons used. 44.8 mpg's. dash computer showed 45.1, so pretty accurate. the interstate on the way home drug it down, as the mpg reading going there was 48.8. hyvrid schmybrid!! |
#14 | |
#15 | |
Yaris real life MPG is mid to high 30's: http://www.fuelly.com/car/toyota/yaris On the other hand, Prius averages 47 MPG in real life: http://www.fuelly.com/car/toyota/prius If you drove a Prius with your hypermilling skills, you would get 60 MPG easily. I'm not even going to get to the argument that Yaris is subcompact while Prius is midsize. |
#16 | |
ive seen plenty of others get in the mid 40's with the manual yaris. people getting mid-upper 30's has to be driving a bit hard. i would have to try to get under 40. |
#17 | |
Only Happy When it Rains
And yes, the Prius barely fits into the midsize category only because they made it as open as possible. It is still on the smaller size of the midsize spectrum, and unless you do a ton of city driving and drive to get the best gas mileage, as you might do, it isn't worth it. But hey, you want to use the masses to judge fuel economy? Fine. fuelly gets 47. Which is absolutely pathetic. The last time I actually had to drive on a freeway, I did that in my Yaris. Now let's actually be honest here. The Prius and the Yaris are cross shopped. The main reason to by both is because of gas mileage. I looked at both before I bought my Yaris in may of 2006. I, like many on here went with the Yaris because the extra gas mileage simply was not going to make up the price differential short of $8 a gallon gas. And since you like fuelly so much, here is mine. ![]() I almost never do anything like freeway style driving to boost that number up, the closest I get is state highways with tons of lights, cars stopping to take turns, and the like. And unlike most hypermilers, I use my cruise as much as possible, I very rarely drive to endanger like they do, about the only thing I do is drive the actual posted speed limit, and not act like a dumb ass drag racer.
Colin Chapman disciple |
#18 | |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
While your sooooo happy with the prius, lets not forget the extra 1/2 ton of toxic waste the earth needs to deal with, when I prius is wrecked.
This is something very few(if any)Prius owners every deal with or think about. The Prius is loaded with toxic waste! And Prius owners are helping to pollute our planet, Just so they can feel warm and fuzzy about using less gasoline. Quote:
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 09:38 PM |
| Custom Lftback - Photo-Scavenger Hunt | custom Lftback | Photo-Video-Media Gallery | 2 | 03-02-2009 12:12 AM |
| Darb - Photo Scavenger Hunt | Darb | Photo-Video-Media Gallery | 3 | 03-01-2009 10:02 PM |
| Black Yaris - Photo-Scavenger Hunt | Black Yaris | Photo-Video-Media Gallery | 2 | 03-01-2009 05:13 PM |
