#1 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
I don't know why I was thinking your Yaris was about out of warranty
![]() I guess I just assumed it was nearly out of warranty and you decided it was time to switch to 0w20 API is kinda important to me, and AutoZone had the Mobil 1 0w-30 for $6.95, so I bought 4 Blackstone labs will be doing both of my UOAs If Mobil 1 tests out better than the PP 5w-30 I'll shop for it at WalMart next time. |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
The Blackstone folks are great-exceptional customer service. They helped me out with a special need testing situation a while back on a HD rear axle.
My hunch is the M1 will do quite well in this app. Is it the new green cap AFE? |
#3 | |
I'm hoping the M1 does well, if not I'll stick with the $3.95 PP :) |
#4 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
I just had to dump Castrol 5w30 syntec BC the engine was so noisy that i though it was gonna blow. I have Rotella T 10w30 CJ4 in there now, and this is the BEST overall conventional oil ive used in the past 5 years - actually the only satisfactory one. Alot of our engines have different needs and mine will absolutely not tolerate light grade oil. Toyota recommends heavier oil (5w40, 10w40 for severe service, high speed driving and towing) in my owners manual not lighter. Since I drive hard, I will need the heavier oil to survive. I dont like engines that clak and tick and clang and dont rev hard to redline. With the thicker oil they are dead quiet and smooth and will have less crankcase fuel dilution - important with E10 "gasohol" usage. Just my dos centavos
P.S: Why does the TSB say in the Red box at the beginning of the TSB to "Use the oil grade on your fill cap" then say somewhere else you can use something else - If I had a warranty issue on 20wt oil - I would be afraid they'd deny due to wrong weight. Untill they send ME a supplement to my owners manual I would never run 20wt - the TSB are not for consumer/customer dissemination, only for dealer use. |
#5 |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
I wonder what the mpg differential is using the 5-20 versus the 5-30? Any one know?
#6 |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
1% to 2%....over 100,000 miles this adds up to over $100 savings in fuel...but more importantly, using 0w-20 means the engine will last longer over heavier oil, and in most conditions. See my post above for more reason on this.
#7 |
Crazy Oil Sniffer
Ecomodder is a cool place-I find myself lurking there quite often!
R2 |
#8 |
Crazy Oil Sniffer
Silky,
With all due respect if Dr AE Haas can run 20 wts in an Enzo and a Lamborghini I think a stock Yaris will do fine on it if it's a quality oil formulation. I bet the Enzo and Lambo don't mention 0W-20 or 0W-30 in there manuals either. :) I thought you were initially pleased with the Syntec? I believe you had "padded" it with some 10W-40, correct? The noise you keep referring to-when is it occuring? My Yaris is a little noisy when "cold" but is very quiet when fully warmed up and the oil is at it's "thinnest". I have always used 20 wt so far and have heard rumors the factory fill was a 20 also (I have no proof for this yet). Engine loves to rev but rarely gets to as I putt around and gawk at my ecometer! The Rotella is a nice oil but would make me uneasy during a NH winter! Sure, I think it will start fine but it may (rather loudly) protest. Hope it works out for you better than the Syntec-let us know! R2 |
#9 | |
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 10-29-2009 at 08:24 AM. |
#10 | |
#11 |
Crazy Oil Sniffer
1st,
You got me thinking about sampling the 5W-20 I've currently got in the car. It will only have about 2k on it but I still think it would be interesting to see. I've got a Schaeffer sample kit here (no TBN but its only 2k). I think I will sample it just as a starting point but honestly even if it doesn't look great I won't be concerned because the engine is so young. Should happen early next week. R2 |
#12 |
Crazy Oil Sniffer
1st,
I have the report back on the last (short!) 5W-20 fill from the Yaris. 2009 Yaris 1.5 L Oil was Schaeffer's 7000 5W-20 with 1871 miles on it and 4974 on the car total at time of sample. Analysis by Schaeffer. Copper - 3 Iron. - 7 Cromium- 0 Alum. - 7 Lead. - 0 Moly. - 329 Phos. - 963 Zinc. - 1115 Magnes. - 294 Calcium. - 2095 Sodium. - 8 Potass. - 3 Silicon. - 20 Antifreeze, water, fuel all nil. Visc @ 100C. 8.07 (20 wt) Oxidation % allowed 0 Nitration % allowed. 6 Looks good for such a young engine IMO. The next sample will be much more informative but we at least know nothing disastrous is going on. R2 |
#13 |
![]() ![]() Drives: '07 Yaris, '12 GLI Join Date: May 2007
R2, are you going to post this on BITOG or can I?
#14 | |
OIL BRAND: Valvoline OIL TYPE: Durablend 5w20 SAMPLE DATE: 08/20/2009 TIME ON OIL: 4,930 MILES VEHICLE MILEAGE: 15,104 SPECTROCHEMICAL ANALYSIS (ppm) SPECTROCHEMICAL ANALYSIS (ppm) 12 - IRON 0 - CHROMIUM 0 - LEAD 3 - COPPER 0 - TIN 2 - ALUMINUM 0 - NICKEL 0 - SILVER 13 - SILICON 13 - BORON 140 - SODIUM 10 - MAGNESIUM 2441 - CALCIUM 0 - BARIUM 789 - PHOSPHORUS 861 - ZINC 7 - MOLYBDENUM 0 - TITANIUM 0 - VANADIUM 0 - POTASSIUM PHYSICAL PROPERTIES <1 - FUEL (% VOL) N/A - VIS @ 40 C cSt 8.52 - VIS @ 100 C cSt 0 - WATER (% VOL) N/A - SOOT/SOLIDS (% WT) NO - COOLANT |
#15 |
Crazy Oil Sniffer
Craig,
Yeah I'll post soon. I'll probably get hammered for changing it so soon but I like to get the break in metals out of there so I usually do several short fills early on. I also forgot to mention this was a 3.5 qt fill with 7 oz of LC20 at time oil was installed + 2 oz at the 1k mark. Just wanted a peek at what was going on after 1st Toyota got me thinking about it. |
#16 |
If you are going for longevity for your engine, if you want it to last an absolute long time, then use 0w-20. Using 0w-20 will allow the engine to last longer then if you ran heavier oil.
This is because the lighter oil protects better during the time the engine wears the most: First 5-10 minutes of running after the first start in the morning. At operational temperatures, there is a teeny tiny insignificant difference in engine wear between 20 and 30 and 40. What kills engines is NOT running them at 212F on the freeway...what kills them is running the engines cold because cold means 10w-30 runs thicker then 0w-20 which means it circulates to the top and around all the internal engine parts SLOWER then 0w-20, and means more wear during the time engines wear the fastest: first 5-10 minutes of running for the day. If you really know oil, understand how it works, you will see this is true. If you don't understand, you will have this dillusion that thicker protects better. The only time you want to run the really thick stuff (40 weight for example) is if you are running hard, fast (racing or uphill under termendous load), and for long periods of time, in very hot weather. But for most of us, this is the exception and not the rule. If you want your engine to last it's absolute longest, go 20 weight over 30 or heavier. |
#17 | |
- Aside: You need lube to get up in the ring pack and stay on the wear areas. This is NOT PAO group iv synthetic, a terrible lubricant but with good cold flow properties. So oil base stock magic makes a diff too. Conventional is better and most 20wt-er's swear by Grp II+ motorcraft SS. |
#18 | |
Synthetic oil is better then any and all conventional because synthetic is less prone to (1) shearing, and (2) oxidation. For longevity purposes, I'd prefer synthetic....however, if one only uses conventional, this engine will still last a heck of a long time...also, I don't know of a conventional oil that provides 0w weight. |
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 02:40 PM |
| Finally! | KittenRD | New YARIS Purchase Forum | 6 | 01-01-2007 09:16 PM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 04:24 PM |
| finally found a good product to clean al plastic parts | Adriaan | Wash, Wax, Detailing, Exterior Repairs | 4 | 12-01-2006 02:45 PM |
| It's finally here! | Cathy | New YARIS Purchase Forum | 10 | 08-29-2006 10:08 AM |
