#37 |
It's always going to come back to RMS power for me. I've used PowerAmp since my T-Mobile G1, the very first US Android Phone. Wonderful app, but it's no substitute for RMS power.
As 06Yaris has said, you'll probably be happy with either unit. I'm late to the party on answering the question of should you buy the Chinese Android unit or the Pioneer since you already made the purchase but for what it's worth, my pick would have been the Pioneer. |
#38 | |
![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
ASAP information+opinions for Android Headunit.
Both had like the same rms power, as I saw. I know pioneer was the safe choice. But in the same amount of money, with this particular Android HU, I think I give less for much more. I mean with the same amount of money, I have a big screen (which I don’t get with the pioneer), I get maps (which I don’t get with pioneer), I keep the factory look of my car (which... well you get the point) and I have access to a huge app library, with useful apps like torque etc. I bet pioneer has better sound processing chip. But I don’t think that the Android HU is that far off... these things have come a long way in the last year, due to demand and the smoother Experience newer Android flavors (7.0, 8.0) offer. Time and usage will tell. I will keep you updated. Poweramp will be in my app list for sure. Thanks for the recommendation. Also, does anyone of you has to recommend a better EQ app? I haven’t use the stock thought yet because I don’t have the HU in my hands, so I don’t know if I need a better one anyway Sent from my iPhone using Tapatalk |
#39 | |
![]() ![]() ![]() ![]() ![]() Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ |
#40 | |
Thank you, I hope I will be pleased. I would love some help with these settings since I am new to this. Thank you So poweramp applies eq settings in the whole system? Or just the songs I play within the app? Haha once you get in the sound upgrade path, you can never stop. I was always wondering what people think when they turn their cars into a transformer full of speakers and when I decided to upgrade my sound system, the list went on and on and on. I made some mistakes in the beginning, I bought a pair of speakers that I shouldn’t have, because they had build in tweeters (coaxials) and I placed them in the front, while I had already tweeters from the factory in the a pillars, so there was no depth in the sound, no bass, only highs. After that I bought the other set which I have right now. They are stock speakers from VW group, but to me, they sound amazing (I have upload some pics of them in an other post I made about some interior upgrades I did, and you can really see the difference in quality between them and the stock Yaris speakers : Neat-cheap interior mods that makes a huge difference. https://r.tapatalk.com/shareLink?sha...0&share_type=t I had experience with them before due to our previous car (Audi a5) and I knew that their stock speakers are pretty good, so I bought 4 used of them and I couldn’t be happier. Total cost of them 40$. Now with the new HU I think they will shine. For now I will try to hold myself from spending more money on amp and sub. But I know that at some point I will do it for sure ![]() Sent from my iPhone using Tapatalk Last edited by miiser; 10-02-2018 at 07:31 AM. |
#41 | |
Sounds like those speakers will work well. Most aftermarket speakers, whether low or high end, I believe, will not come into their own without an amplifier. Maybe the low impedance speakers like some of the Polks or Infinitys would give better results with head unit power alone. I think OEM speakers are more efficient, demand less power, and as a result may sound better than aftermarket if powered only by a stock head unit. My experience has always been that just adding an aftermarket speaker will improve the clarity, but results in less perceivable bass response.
#42 | |
That’s exactly what I figured out, too. I bought these speakers, because they demand less power and they work really well if you are on a budget. With a new HU, with more settings than our factory one they can really shine. Even with the crappy stock Yaris speakers you can improve the sound by using a new headunit, or at least that’s what a member here told me. With aftermarket speakers you have to get an amp sooner or later otherwise you miss depth and bass response. So to anybody else who’s thinking buying a new pair of speakers, without having an amp, guys buy a pair of used factory speakers of another, more expensive car (I heavily recommend the vw speakers, but it’s up to you). Just make sure that the ohm independence is 4ohms if you are going to use them with the stock headunit . They will make wonders. Sent from my iPhone using Tapatalk |
#43 |
![]() It’s here guys. And it looks amazing ! Sent from my iPhone using Tapatalk |
#44 |
As you had said, looks like a perfect replacement/fit.
#45 |
Head unit looks awesome! Looking forward to your impressions.
#46 |
After 3 days trying to fix the radio reception which was terrible, I finally found the problem. I had to stop acting like an idiot and then use the correct connector for the antenna. (I was using a tv antenna connector and I thought it will be the same. Wrong !)Now everything is perfect. But the radio still has static sounds. every fm station is playing but all of them have static issues.. any idea on how to fix this? How to make it better ? Is this a problem only on these Android HUs or in every 2 din conversion (pioneer etc) ? Sent from my iPhone using Tapatalk Last edited by miiser; 10-10-2018 at 02:09 PM. |
#47 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
There is an amplifier in the antenna base that needs 12 volt power applied. Without the power, the radio reception is very poor. From memory, on my series 3 this was a black wire thag runs with the antenna lead. Most after market radios will have a switched 12 volt output that can be used to power the antenna anmplifier.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#48 | |
I did that Kevin. I found the wire (it was a blue one) and I plugged it on an unused connector wire with an AMP tag sticker on it. But still nothing.. Sent from my iPhone using Tapatalk |
#49 |
The factory antenna connector with the 2 wires you mentioned :
![]() I thought by plugging it in the amp connector wire I would have better reception. But it exactly the same... with or without Maaaybe a blown fuse of the antenna amp? Which is the fuse for it? Sent from my iPhone using Tapatalk Last edited by miiser; 10-12-2018 at 01:05 AM. |
| Need opinions on these wheels ASAP! | PumpkinSteve | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-16-2011 02:26 PM |
| Need some new headunit opinions | pvt_melfi13b | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 06-28-2010 06:54 AM |
