Old 04-14-2020, 10:27 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by kappa_md View Post
The rotor comes with a different bracket but the stock caliper is the same. Brake pads are also the same size, but probably it’s good to get better compound. It can handle size 15s wheels according to the website but i think it’s stretching it a bit. The 16s is better for clearances imho. All in all there’s marked improvement in brake feel since i’m driving the yaris into it’s limits. One thing i observed with slotted and/or drilled rotors is that, braking power remains the same with blanks, but brake fade is far less with those slotted and drilled. Probably you can notice it during track days but hardly as street use.
Ah, the caliper bracket makes sense. Interesting observations about the drilled/drilled rotors. I think if I went forward, I would go with blank rotors. I don't find the stock brakes bad and they seem capable for how I drive. Maybe I will start with Hawk pads. I actually have a set of blank rotors on my shelf in the garage. They are cheap rotors, but I'll see how they work with the Hawk pads. Thanks for the great info!
Old 04-15-2020, 02:51 PM   #2
looks good, are you doing something more interesting than silver?
i've run most of the wheel/tire sizes. actually, we were in fredericton, nb when we bought our 2007 CE. came with factory 14's. "crandall" also lived in freddy beach and he ran 17's. HUGE difference in acceleration and braking between 14's and 17's (17's made the car accelerate slower and you had to press the brake pedal harder to stop (never did a true "versus" brake test, just me driving his car))
I eventually stayed with a 15x7 and a 205-50-15 on my yaris...comfort and handling.
205-50-16 are a bit tall vs your OEM tire, no?
Old 04-15-2020, 09:21 PM   #3
06YarisRS
Thanks. I'm going to stick with silver, not being very adventurous. I actually have a pint of Toyota silver wheel paint in my shop. What color would you paint them?
Initially, I upsized from 185/60R15 to a 195/60R15 on my stock wheels which are, I believe, 5.5" wide. Part of the reason for upsizing the wheels was to be able to use a slightly wider tire. I wanted a 16" wheel and one that resembled the stock rim as much as possible. Enter, the Accent wheels. Since I have lots of additional power and torque, upsizing isn't an issue, but yes, I noticed a big difference just between the 14" tiny winter rims and tires (175/65R14) vs the 185/60R15s on my stock 2008 LE.
Since I love visuals - and playing with the tire comparison tool - here are a couple pics to illustrate the discussed tire sizes.
Stock RS tire vs Current 205/50R16
My 195/60R15 vs 205/50R16
Old 04-15-2020, 11:09 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
I didn't notice any real difference in acceleration when I switched from 185/60/15's to 205/50/16's. But, I did notice a huge improvement in handling... and of course, the car looked so much better IMHO. Surprisingly, the speedo was bang on with the 205/50/16's.
However, I experienced a significant difference in acceleration and even better handling when I decided to put light weight 16's on the car; it was like night and day... like driving a completely different car!
Old 04-20-2020, 04:49 PM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Further to Kimona's point, I'd bet my bottom dollar that my 17x7 wheels weighing in at 14.6 lbs each outperform heavier 16" options in both acceleration and handling. Un-sprung corner weight is a mother.
06 knows I'm a super fan of both his Yaris and workmanship. Having said that, both the design and color of these Hyundai wheels strike me as too similar to the stocks you were running previously. Given that they're probably heavier, I might have held out for something else.
To barber's point, perhaps a diff color, at minimum. It's not as though it doesn't look fantastic but given all the work, I'd think you'd have wanted more change effect. All respect due, just my 2 cents.
On Instagram
On Wheelwell
Old 04-20-2020, 07:17 PM   #6
IIRC, the OP is a big fan of the old RS wheels but desperately wanted bigger. In my thinking, that would be why he went with near identical look and still keeping OE silver. Also, with all his new found power, something that would easily negatively impact a factory 1NZ will probably be barely felt.
Old 04-20-2020, 11:25 PM   #7
06YarisRS
Thanks for the input gents! Interesting points made here. My interest in the wheel change is, as WeeYari says, to upsize the capacity for a wider tire, plus have the look of a 16. I do love the stock RS wheel design, but the tire looks too big on the wheel, IMO. Kind of like a big donut. It is true that I have tried to maintain as stock a look as possible while pushing things ever so slightly (lip, rear spoiler, and now wheels). The Hyundai wheel met virtually all of my criteria, the obvious being the bolt pattern, but also the offset (ET47), as opposed to the Yaris (ET46). It also has 5 spokes, and looks, IMO, a little more elegant with the slimmer spokes. It truly was the closest I could find to the RS wheel at my budget. Did I mention that the Toyota center caps snap right in?
In some respects, I'm pretty conservative when it comes to the car's appearance. Generally, I find that the manufacturer does the best job of coordinating things for an overall look. However, part of me wants to make a more radical change as suggested by Barber and Ernie. I have been seriously considering picking up another set of these wheels. I can get a set for $125.00. I love restoring these and would welcome doing another set...in a satin or semigloss black. That, currently, would be the extent of my adventurousness, I'm afraid. Lol. I kind of like the idea of having a wardrobe (is that the correct term?) of wheel/tire combinations to swap out depending on my mood. LOL. I have two industrial floor jacks and an electric impact gun, so it might take 15 minutes to change out a set of wheels including torquing the lugnuts.
Old 04-21-2020, 02:02 PM   #8
kimona
kimona's Avatar
Originally Posted by 06YarisRS View Post
It is true that I have tried to maintain as stock a look as possible while pushing things ever so slightly...
That's pretty much been my approach as well.
On my 2007, I thought I pushed the stock look a little by going with the 5-spokes (photo in post #9). Then, I found the ASA AR1 (pic below) which I immediately liked, and I thought they looked great on the car! I had them on my car for quite some time while storing the 5-spokes. Having two sets of wheels also allowed me to experiment with numerous tyre tread designs to eventually discover which worked best for overall performance and straight-line tracking at highway speeds.
I put the 5-spokes on my 2014, and I was quite satisfied. But, old school Japanese wheels caught my fancy one day, and I finally decided to really take a chance and break away from the stock look. The result was a new appearance that I fell in love with, and the surprise was the advantage of a light weight wheel.
Old 04-21-2020, 03:19 PM   #9
ern-diz
ern-diz's Avatar
Makes sense.
Love the wardrobe idea!
On Instagram
On Wheelwell
Old 04-25-2020, 01:10 PM   #10
I've done 17s before which are still taking up space in my garage. Never again that size on this car.
Old 04-25-2020, 03:22 PM   #11
06YarisRS
Too rough a ride? They do tend to look good in pics, but my suspicion is that they would be a little harsh. Even the 16" with the 50 aspect ratio on my car is firmer than the 195/60R15 on stock alloys. Not by much, but noticeable.
Old 04-25-2020, 05:51 PM   #12
Me on the 17s. Can't believe this was way back in 2013. Wish the car looked as good today. :(
Generally the ride on 17s wasn't too bad. My biggest issue were the potholes that appear out of nowhere booting along at 120. Hitting those makes you feel sick and the first thing you do when you stop is inspect your wheels.
Old 05-04-2020, 02:56 PM   #13
ern-diz
ern-diz's Avatar
Don't be scared; life's short and it looks too good
Consider that many people run 18's on their Yaris' That's even too much for me
On Instagram
On Wheelwell
Electrical Journey Seeking Electrical Guru Advice longlivekel DIY / Maintenance / Service 15 10-29-2019 10:19 PM
**** Seeking Advice: I Need Frame straightening And what Insurance said + Pictures ** yarisa General Yaris / Vitz Discussion 7 08-18-2017 09:22 AM
Seeking advice head unit replacement - 2006 Yaris NCP91R aa11 In Car Entertainment + Electronics (audio / video / alarm) 2 01-01-2014 10:54 AM
Tire advice for 17" wheels coolj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-12-2011 01:06 PM
1st-Time Buyer Seeking Advice Oh,That Guy. New YARIS Purchase Forum 20 08-28-2010 12:13 AM
