Old 06-15-2020, 07:34 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Originally Posted by Leegamer View Post
The obvious solution is to get another engine and trans and build them on the side, then you can keep driving in the mean time.
The man has a point!
On Instagram
On Wheelwell
Old 06-16-2020, 01:04 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yes, he does.
Old 06-16-2020, 01:03 AM   #3
06YarisRS
Haha! Not a bad idea actually.
Old 06-16-2020, 08:44 AM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Shhhh! It's sleeping!
Old 06-20-2020, 01:50 AM   #5
06YarisRS
LOL
Old 06-20-2020, 02:03 AM   #6
06YarisRS
Well, after experimentation with various mixtures of water/methanol, I have come to a conclusion... the final mixture of water to methanol is 100/0.
Here's my reasoning: I have been playing with o2 spoofing by entering different voltages in the o2 map. I have managed to achieve a solid 12.0:1 AFR between 3 - 6 psi, in closed loop operations/partial throttle/partial boost. At WOT, and transition to open loop, I have 11.5:1. This is with straight water injection. When I start adding methanol, the AFR is naturally affected and the stock ECU starts to get cranky (no reference to you, Sam) and it wants to buck a bit as the AFR gauge flops back and forth. Water seems to be doing a great job at keeping EGTs within a good range. With methanol being injected, the factory ECU wants to pull fuel (on the order of -10 to -12) and EGTs seem to climb.
I may revisit methanol in the future once I more accurately nail down the o2 spoofing voltages in the F/IC. I may however in the meantime - with great caution - advance the timing a wee bit now that I have a pretty solid effective octane rating. For now the car runs great, pulls very hard and I'm feeling safe boosting for longer periods of time and more frequently.
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Water Injection Toy_Yoda Forced Induction Forum 3 05-04-2013 09:20 PM
FS: Blitz Supercharger + AEM Water/Methanol Injection Kit fmicle Items for Sale by private party 22 03-08-2013 01:46 AM
FS: AEM Water/Methanol Injection Kit fmicle Items for Sale by private party 0 02-19-2011 01:59 AM
