Old 12-28-2006, 12:17 PM   #1
spkrman
Drives: 1
wow whats goin on there lol
Old 12-28-2006, 12:23 PM   #2
ChinoCharles
Drives: LB
What kind of HUD do you have and how is it Tamago?
Old 12-28-2006, 02:08 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
Defi Basis
Old 12-28-2006, 02:19 PM   #4
spkrman
Drives: 1
http://www.yarisworld.com/forums/sho...4589#post44589
w00t :)
Old 01-01-2007, 02:27 PM   #5
KSIbucky
KSIbucky's Avatar
i was wondering i have a seven color tach and every time i start the car it goes back to the default color
the problem is i need to connect to the battery i think i was wondering what wire should i tap or whatever
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 01-02-2007, 08:04 PM   #6
spkrman
Drives: 1
I tapped the wire from the cd player, thats always an easy/foolproof way to get ignition/illum/power.
I've fixed/created way too many noisy grounds... so I just used the ground location detailed in this DIY, although you could obviously tap ANY location on the body, and the A pillar would have been the shortest path, but doing it this way I didnt have to take it all the way off.
To do the wiring in another yaris would take me about 5 minutes.
For future reference, don't power anything off the illum wire, wire up a relay if you are doing more than, well, powering a relay
Old 04-22-2007, 04:30 PM   #7
wagoneer
wagoneer's Avatar
Drives: 07 Liftback - Red
[QUOTE=spkrman;45391]I tapped the wire from the cd player, thats always an easy/foolproof way to get ignition/illum/power.
QUOTE]
Specifically, where at, what color, and how do you get to this wire? I need to hook my "Illumination wire" to a constant source of 12V so the Tach will remember which color is selected...
DRL removed
rear debadged
Tachometer installed
Mudguards installed
Rear Bumper Guard installed
FUTURE = Fog Lights, arm rest, RS spoiler, cruise, black 17" wheels
wagoneer is offline   Reply With Quote
Old 04-23-2007, 06:53 PM   #8
wagoneer
wagoneer's Avatar
O.k.
Here is the definitive way to do it for a Glow Shift tach that changes colors.
Buy 2 Mini Add A Cicuit Fuse things described in this thread. There are two sizes, Mini and Regular get the Mini, 2 of them.
Attach the tachometer "12v IGN" (Red wire) to one of the add a fuse circuits. Attach the add a fuse to terminal #24 in the fuse box located where described in this thread.
Attach the tachometer "Illumination" (yellow wire) to the other add a fuse circuit. Install this add a circuit at terminal 8 or 9 (the red 10amp circuit across from #24 location). This will ensure that the tachometer "remembers" what color it was last on after you shut the car off.
Attach the tachometer "signal" (green wire) to the OBD scan port far left blue/green wire as described in this thread.
Attach the tachometer ground (black wire) to the bolt as described in this thread.
Working like a champ and it remembers what color it was last on when I start the car back up.
DRL removed
rear debadged
Mudguards installed
Old 03-07-2007, 09:55 AM   #9
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
anyone know where the #24 fuse is for red wire is? I've been looking for it all day. Also, so the white wire goes some where else? The green tach wire still goes to the far left green-blue wire that is part of the underdash neon plug? thanks
Old 03-07-2007, 10:10 AM   #10
MrJester
Drives: homo
the #24 fuse is located under the dash on the drivers side. Look all the way up under there adn there should be a small black cover over the fuses. :)
MrJester is offline   Reply With Quote
Old 03-07-2007, 10:21 AM   #11
slothman86
slothman86's Avatar
yep found it thanks...now for the next question, how'd he get the power wire attached to that fuse?
Old 03-07-2007, 10:57 AM   #12
MrJester
Drives: homo
Try one of these
http://grote.com//cgi-bin/goc/goc.cg...number=82-2212
Old 08-09-2007, 12:01 PM   #13
meteoriteyaris
meteoriteyaris's Avatar
Drives: 2007 Meteorite metallic
Those Grote add-a-fuse things are $22 each here at NAPA. I'd need two and I didn't pay that much for the tach. Anybody know of any place to buy them for a reasonable amount?
meteoriteyaris is offline   Reply With Quote
Old 03-07-2007, 11:40 AM   #14
slothman86
slothman86's Avatar
hey, thats a big help thanks alot!
Old 03-08-2007, 11:15 AM   #15
Lafiro
Drives: 06 Yaris Sedan
Better pictures, maybe daytime?
I can't see anything clear except your face......
Old 04-21-2007, 02:08 PM   #16
wagoneer
wagoneer's Avatar
I installed my tachometer today.
Glowshift 7 color tach with universal gauge pod.
Installed at A pillar as others.
Wired Red Tach wire to the #24 fuse as described (utilized a mini add a fuse as also described in this thread)
Wired the Black Tach wire to the bolt at bottom of A pillar as described in this thread.
Wired the Green Tach wire to the far left blue green wire at the OBD scan port as described in this thread.
I wired the Yellow "Illumination" tach wire to the brown wire at the dimmer switch.
However, my tach cannot remember which color it was on when I turn it off and back on. It also doesn't brighten/dim with the dimmer switch.
Directions say to "connect the yellow illumination wire to the positive side of the battery". So it needs to be something that is always powered, even when key is off.
Where the heck should I be putting this yellow wire????
DRL removed
rear debadged
Mudguards installed
Old 04-21-2007, 11:40 PM   #17
uncleyaris
ouch! good luck
Old 04-23-2007, 08:16 PM   #18
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Some one should install it into the vent thingie!!!!!! haha i think that'd look pretty nice
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
