Old 09-21-2006, 01:32 PM   #37
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by barryware
Keep in mind... This mod also disables the "Brake" light warning that you have when your parking brake on.
It was the same on a VW I had. The DRL relay also supplies power to the parking brake warning light when the ignition is on.
Do you speak from experience?
With the DRL's disabled, and the parking hand brake in the up/locked position, the brake light in the dash cluster DOES light up. Engine running or not, headlights on or off. When its in the down position, the lights off.
Weird that your is different.
Old 09-21-2006, 02:30 PM   #38
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
My ebrake light still comes on as well.
ketel0ne is offline   Reply With Quote
Old 09-21-2006, 04:50 PM   #39
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Originally Posted by Ran Kizama
Nice post. If anyone wants to just get rid of their foglights, let me know. I'll buy them and send you the OEM filler thingies.
Same here....
nick1983 is offline   Reply With Quote
Old 09-26-2006, 08:26 PM   #40
KSIbucky
KSIbucky's Avatar
the think didnt come out how do you get it out witch way do you pull
a picture with arrow would help
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 09-27-2006, 01:22 PM   #41
Chris07LB
Chris07LB's Avatar
Dissconnect the plug, and pull the DRL box out. Simple.
Old 09-27-2006, 01:42 PM   #42
ChinoCharles
Drives: LB
There is a slot on the side of the relay where a bracket slides in. First, push the relay in the direction opposite to the base of this bracket. This will remove the relay, and then it is just a matter of disconnecting the wires. When I did this I tried to disconnect the wires first, but unless you're 3 and have the hands of Tinkerbell this won't work, or it will work and you'll have busted knuckles. Either way, remove the box first.
Old 09-27-2006, 01:54 PM   #43
Chris07LB
Chris07LB's Avatar
Thanks for helping charles.
Old 09-27-2006, 02:54 PM   #44
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Once you do this, do the lights on the liftback speedo still come on with the headlights off?
I've driven around with my lights off more than once in my Yaris because I was fooled by the speedometer light. I've never done this so many times in nearly 30 years of driving.
Old 09-27-2006, 03:43 PM   #45
ChinoCharles
Drives: LB
No problem hombre. Your hat makes me want Chipotle...
I am assuming you mean the green light that comes on when your lights are fully engaged. Without the DRL box, everything works just fine. When the lights are off, the green light remains off, and when they're on it comes on. What you're talking about is exactly why I removed them. Previously I drove a Cadillac for a few years with automatic lights, so I never had to turn them on. In the Yaris, the DRL's had me thinking that my lights were on at night when it was only my headlights that were on. I got pulled over the second day I had the car for not having my lights fully on and was given a warning. This happened a couple more times before I decided that even though I haven't bought HID's yet the removal was still a good idea. It was a safety/ADD issue.
Old 09-27-2006, 04:23 PM   #46
Violin
Violin's Avatar
Actually what I am referring to is the illumination on the speedometer. With that illuminated, I am fooled into thinking my headlights are on.
Does that stay illuminated all the time with the DRL's disconnected?
Old 09-27-2006, 05:05 PM   #47
Chris07LB
Chris07LB's Avatar
Gauge cluster performs the same with or without the DRL modual being dissconnected.
Old 09-27-2006, 05:11 PM   #48
Violin
Violin's Avatar
Dang!
Old 09-27-2006, 09:21 PM   #49
Toymaniac
Adm.ClubYarisQuebec.com
Toymaniac's Avatar
Drives: 2007 Yaris Sedan Aero group
FYI in canada since 1993 every new car sold as to have Day time running lights
Toymaniac
2007 Yaris sedan Barcelona Red
TRD Swaybar
TRD Springs
Tanabe Strutbar
Toymaniac is offline   Reply With Quote
Old 09-28-2006, 10:11 AM   #50
Chris07LB
Chris07LB's Avatar
Not sure what year it started in the US, but it's not a "law" here to have to keep them armed.
Toyota has a few TSB's for their dealers to disable the DRL's on select models. Couldnt find one for the Yaris, so hence the reason for me sharing my finds with this post.
Old 09-28-2006, 10:41 AM   #51
H8SGAS
H8SGAS's Avatar
Drives: Black Liftback
YEAH!!! I thought I was the only dope running around at night/early morning with no tail lights on! Several times I have got into the car all sleepyish after work, then I see my "head lights" so I'm not thinking they are not actually on! Exactly the reason I'm pulling my box too, before "The Man" gets me too
Well if it’s not a hybrid how do you get such good mileage?
H8SGAS is offline   Reply With Quote
Old 10-16-2006, 10:47 AM   #52
Chris07LB
Chris07LB's Avatar
<> BUMP 4 THE NEWBIES <>
Old 10-21-2006, 10:12 AM   #53
anybody has the wiring diagram for the DRL ? i want to rewire it to other lights, such as fogs..
Old 10-21-2006, 12:54 PM   #54
ChinoCharles
Drives: LB
Now that would be cool...
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
