Old 03-31-2010, 11:31 AM   #19
swidd
Drives: Yaris HB
So... am I just weak, or are those bolts near impossible to unscrew? I couldn't do it... When I tried using a drill, the extension part I insert into the drill broke off, and didn't move the Toyota seat screw at all...
Old 03-31-2010, 11:41 AM   #20
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I'm about to take the front seats out, I'll let you know
CLA 250, 4MATIC
Old 03-31-2010, 12:20 PM   #21
swidd
Drives: Yaris HB
Please do. I tried again, with a socket wrench. No success. I'm thinking it may be welded from the bottom or sealed with very permanent lock-tite... Or that going to the gym didn't help my strength...
Old 03-31-2010, 12:28 PM   #22
that is a starz bolt. it's on there real tight, but you can get it off, it is not welded.
get a short pipe to increase the torque and use the correct socket for that bolt.
Old 03-31-2010, 12:33 PM   #23
swidd
Drives: Yaris HB
lol, I configured my socket wrench short, and was able to twist the bolt about 1/2 rotation, and then that socket head (actually converter piece) broke too! I bow to the mighty Yaris... Now my whole 40 piece socket wrench kit is useless without that converter piece.
Old 03-31-2010, 01:35 PM   #24
RedRide
RedRide's Avatar
As somone who has worked for Ford (in assembly) in the '70s, I can testify that seat bolts are given the upmost importance both in strength and torque right up there with seat belt mounting bolts.
I suspect that perhaps loctite is is used to secure them.
Old 03-31-2010, 01:40 PM   #25
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Or, you can do what I've done on certain cars, and buy a bath towel from Walmart to put under you that you can fold, easily, in various ways, to provide support wherever you need it on a long drive. Works great. And I've never heard anyone seriously question the hardness of Walmart's towel bolts.
sbergman27 is offline   Reply With Quote
Old 03-31-2010, 03:00 PM   #26
swidd
Drives: Yaris HB
Alright, it finally gave in. Brute force!! ... And $5.99 to auto zone.
Just so I'm sure, I can disconnect the wire harness under the seat and remove the seat, and continue driving with the seat removed for a few days without the airbags deploying?
Old 06-10-2010, 11:55 PM   #27
Wayboo
Drives: Red two door hatchback
Seat mod works great thanks
Wayboo is offline   Reply With Quote
Old 07-13-2010, 02:54 PM   #28
frostbitten
Drives: yaris 07 3dr
yup
frostbitten is offline   Reply With Quote
Old 06-29-2011, 04:07 PM   #29
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
Hey drudging up an oooold DIY thread here. So I get severe leg pain on long drives (3+ hours) because I am 6'2" and I guess I don't really get any support on my right leg. If I lift the seat up in this way so my leg hopefully has a little support and I am not using the muscles on my inner thigh for hours and hours and hoooours to keep my leg in place and work the gas petal, this will hopefully gibe my leg a little more support? Also I think a DIY cruze control would also help since I would not have to mind the gas petal on long drives.
But does anyone else have this particular leg pain or am I just borken? Thanks all.
- Jason
2007 Toyota Yaris Liftback Base 5 Speed.
Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust.
Kiteless is offline   Reply With Quote
Old 06-29-2011, 04:30 PM   #30
^ Lifting the front of the seat with a spacer or washers will help a lot.
Old 10-19-2011, 01:36 AM   #31
darthmynock
Drives: Yaris 2008
So, that is why I can't stand long trips 3hrs or +, b/c of the pain on my leg?
Adding this to my to-do list !!
ty
darthmynock is offline   Reply With Quote
Old 12-10-2013, 11:47 PM   #32
Radvr6t
Toyota Echo NOOB!
Radvr6t's Avatar
Drives: 2005 4dr Echo hatchback
Did this and surprisingly noticed the 5/8ths difference!
2005 Echo hatchback Project (Silver)
Instagram: Lawrencephotography
Radvr6t is offline   Reply With Quote
Old 12-11-2013, 08:57 AM   #33
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I was thinking of putting a small igloo cooler on end and sittin on that.
Not really, I was wanting to sit lower actually. I nearly cannot fit in without bangin my head now, and nearly touch the ceiling where I sit now.
Future mod, no rush.
I had a van once, captain chair install without the riser.
Made you feel like a midget drivin it.
I took my time bolting down the passenger side, and had some fun with my friends for awhile one summer, putting em on their back on take off.
I also had threaded rod as a lock and latch on my driver door.
Those were the days with a rednecked out rat rod van I got for someone owing me 75 bucks and the payoff.
Old 07-20-2014, 07:34 PM   #34
driverofchuckles
driverofchuckles's Avatar
Drives: 2008 Yaris. Manual everything
just did this. took all of 5 min! the difference is AMAZING! it was also my first official "mod" :D i now have mod fever. i want to do it all! my Chuckles (when you're 6'4" and you unfold out of a Yaris it's the usual reaction.) will be epic!
(side note: technically it's Chuckles II as my beloved '93 two door tercel, most basic model out there, was Chuckles I. since this car drives, handles, and feels like that one the name fit)
driverofchuckles is offline   Reply With Quote
Old 08-20-2018, 02:12 PM   #35
YarMatey
Drives: 2008 Toyota Yaris 5dr Liftback
Just picked up the hardware to do this mod. This is my second Yaris and I don’t ever remember having the arse and leg pain for long drives with my first one but I’m happy to have found this mod and hope it helps!
Only reccomendation I can make for other who want to do this mod is to be careful about mixing stainless with other metal types. If moisture is introduced the stainless will react and start to corrode the other metals touching it, which could be a safety concern if it’s the seat track mount.
Great informative write up though! Thanks a bunch!
YarMatey is offline   Reply With Quote
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
front seat room Bigdaddy727705 General Yaris / Vitz Discussion 9 10-30-2013 11:26 AM
Seat cushion for thigh, center armrest left armrest BMGYaris Cosmetic Modifications (Exterior/Interior) 2 07-03-2009 11:51 PM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 01:34 AM
